Go to Post Yes, I think we can all agree that bad people suck. - Joe Johnson [more]
Unread 08-02-2006, 22:59
progcamsrobot progcamsrobot is offline
FRC #0687
progcamsrobot is an unknown quantity at this point
Long Tether Cables
Last year during a regional competition I noticed that some teams had long tether cables that they had made themselves. If anyone know's the schematic for the tether port. It would be greatly appreciated if that team or person would share it.
Unread 08-02-2006, 23:02
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Long Tether Cables
You can just take the tether cable and link it with a standard male/female cable... you should watch going above 2 or 3 cables though... The interference gets pretty rough
Unread 08-02-2006, 23:04
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
You shouldn't need the schematic to extend it - just get a standard straight-through serial cord and daisy-chain it to the end of the provided tether cable. It should work great as long as it's not too long.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
FRC #0687
What I'm aiming to do is have one cable so I don't have to worry about them disconnecting. And also so that I don't have to carry more than one cable.
Unread 08-02-2006, 23:08
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
If all you want is a single cable, but a long one, then i would suggest a 25 foot female to female or male to female with a female to male converter, straight through serial cable. These can be found on many places on line, at computer or electronics stores, or can be made pretty easily.
Good Luck!
-Michael Dessingue
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
It's just a standard DB-15 connector (female on both ends in the case of the red tether cable)... I'd assume you could just cut one end and extend it yourself. Though I don't know at what distance you'd want to stop, seeing as more distance = more interference.
Unread 08-02-2006, 23:09
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I think its a direct pin to pin match, so the schematic is unnecessary, try a multimeter in continuity mode check the pins on the tether cable to see how they match up.
Matt Krass
Unread 08-02-2006, 23:13
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Don't you mean it is a DB-9 end on the cable.. not a DB-15 which is what the joysticks use, the number is the number of pins in the cable. Also if you are buying one, DO NOT get an NULL MODEM cable, this is not what you want. You want straight through.
I would also like the schematic of the tether port because if only 1 wire isn't used then I could use some CAT-5e cable that I have to make one.
BTW someone on here had long tether cables they were selling from their signature...
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 09-02-2006, 00:04
Any of the female to female DB9 cables listed here will do the job.
http://www.cablewholesale.com/catalo...rialcables.htm
This is a 25 foot version for $4.39.
http://www.cablewholesale.com/specs/10d1-03425.htm
25' tethers are common and normal recommendations would be to stay under 50'. I've been able to run long tether cables up to 100 ft without a problem, but mileage may vary. Over 100' you need to power the OI separately, and eventually the signal degrades with too much distance.
P.S. I've used converters to go from serial to Cat5 and back again for long distances, but the OI must be powered separately, and the converters are far more expensive than a $4 serial cable. They just happened to be available to test with.
Unread 09-02-2006, 00:18
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
I can't imagine a CAT5 cable would work that well - unless there were enough grounds to do some twisted pair style noise shielding. Putting two data lines on a twisted pair isn't going to work for more than a foot or two.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 09-02-2006, 18:48
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
If you were to get a male to female cable, then get a gender changer (male to female), you could have a nice long program cable too
Unread 09-02-2006, 18:57
Not sure if sanddrag is still selling them--but he's the one who had that sig.
Unread 09-02-2006, 19:07
BRosser314's Avatar
BRosser314 BRosser314 is offline
Post-A-Holic
AKA: Brandon Rosser
FRC #0469 (Las Guerrillas)
BRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to behold
Send a message via AIM to BRosser314 Send a message via Yahoo to BRosser314
well for those of u that want the cable layout,
program cable pinout guide:
http://www.ifirobotics.com/docs/program-port-4-7-05.pdf
you can follow the same pinout to make a tether just make sure you use the same color wires on each end when connecting to the DB-9 plugs. alos i believe there is other pinouts somewhere on this site, didnt take te time to look
Unread 09-02-2006, 19:08
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Look no further than http://www.chiefdelphi.com/forums/member.php?u=2022 follow the directions, if he hasn't read this yet, he'll answer your PM.
[slightly off topic]A wise man once said, every time someone said tether cable, sanddrag got another post.[/off topicness]
As for more ontopic stuff, I've used cablewholesale.com and they are pretty good for the tether cables, I liked electronics goldmine more, but they went out of stock and never got any more. But, http://search.ebay.com/DB9-cable may help for bargin basement prices.
Unread 09-02-2006, 19:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Yes. I sell long serial cables. A CD Swap posting with all the details will be up as soon as a mod approves it.
If you are looking for a 25' serial cable, look no further. I offer them at about half the price of IFI. PM me if you are interested.
I soon hope to set up an online store and offer 25' female-female cables in red or black.
Accelerometer code ImmortalAres Programming 28 04-06-2005 01:02
Tether heating up! Shu Song Electrical 10 03-02-2005 01:14
FOR SALE: Long serial cables Cheap!!! sanddrag General Forum 10 06-11-2002 15:39
How long should production time be??? archiver 1999 4 23-06-2002 23:16
