Go to Post I highly doubt the game has anything to do with water... - rotolomi [more]
Unread 08-02-2006, 21:15
revolution1737 revolution1737 is offline
Robot Overlord
FRC #1691 (Revolution1737)
revolution1737 will become famous soon enough
Look up table
I am programming an omnidrive system and I decided to make look up tables instead of sin and square root functions. Can somebody point me in the right direction as I have never done something like this?
Unread 08-02-2006, 21:25
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Look up table
Hi, well, basically, you would have something like:
rom const float sin[]={(here, list values of sin, from 1-90, with values separated by commas)};
and then, you would get the sin of the angle, lets say theta==20, by calling:
sin[20];
Hope this helps,
Unread 09-02-2006, 00:46
Robot Overlord
Re: Look up table
Thanks, thats exactly what I wanted. I only have one question. I read in a post by kevin that you could post this table in the eeprom. I was wondering if I should try to put it there or where I call my function.
Unread 09-02-2006, 00:50
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Look up table
I have some code that I started last Fall that might be of some use. One application, trig_table.c/.h, is only run once to create a semi-permanent table in EEPROM. The second application, trig.c/.h, demonstrates how to lookup a value within the table. The code is designed to work with the EEPROM code on my website: http://kevin.org/frc. I haven't written the documentation yet and don't know when I'll have the time, so if you have questions, feel free to ask 'em here. You can find the code here: http://kevin.org/frc/frc_trig.zip.
-Kevin
Kevin Watson
http://kevin.org
Unread 09-02-2006, 01:11
Robot Overlord
Re: Look up table
Speak of the devil -- LOL
Thanks, you just saved me a day of programming. If it's all right I may PM you tomorrow if I come across any glitches.
Thanks
ps I was looking through the code in notepad and I see that there are 8 and 16 bit functions of sin. Are these what I call and if so do I need to call them both?
[RCU]: Kettering Kickoff table Lisa Perez General Forum 0 29-08-2005 12:33
Sortable table for use on webpages Elgin Clock Website Design/Showcase 2 22-05-2005 17:09
full table? Shlomi32 General Forum 2 27-04-2005 10:03
Lookup table generation tool WillyC Programming 12 15-02-2004 21:01
table corruption... round 2 Brandon Martus Announcements 0 18-12-2001 23:57
