Go to Post I also hate it when I keep seeing this message: "You must spread some Reputation around before giving it to Andy Baker again." - dlavery [more]
  #32   Spotlight this post!
Unread 09-02-2006, 01:04
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Re: Stupidest Programming Mistakes
We've had one major error that took -forever- to figure out.
We had this cubic function for the drive system, since it would increase slower... And it built and all, but when we loaded it an error popped up in the IFI command prompt, all in HEX. It took a while until we realized that victors couldn't take floats @.@
Then we had to change our step(which works very well now, speeds up slowly then stops fast, speeds in reverse slowly but goes to 127 again fast.) from .8 to 1 =P All is good now... also we decided to move our autonomous code to a new file, and leave manual in another... Only to forget to change this
#ifndef __399_Code_h_ in our header file to the name of our Autonomous file @.@ That gave us the same hex error stuff... Oh well! All is good now... Except it seems like our cam is fried. =/... Will be able to test it more tommorow =(
EDIT: After reading tons of the messages here, it seems that those hex errors were actually oversized memory? I doubt we have the new IFI loader so eh... I guess maybe we can go back to our cubic. This works good though, so we'll see.
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
VEX programming Gene F Programming 14 08-08-2006 22:21
Suggestion for Delphi Programming Posts Chris Hibner CD Forum Support 1 27-07-2005 10:02
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
