Go to Post The game transcends the competition, and this is beautiful. - Taylor [more]
  #121   Spotlight this post!
Unread 08-02-2006, 07:22
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
Re: 3D Animation Q/A
you can just make a bulb and turn up the self illumination, and if yu use radiosity or lighttracer, there is an option to turn the bulb into a light emitter.
alternatively, you can make an area omni, make it visible, and make it a sphere. I don't have max with me, but if you look in the MR omni optoins, look for a check box that says "make visible in renderer"
  #122   Spotlight this post!
Unread 08-02-2006, 19:50
animator1's Avatar
animator1 animator1 is offline
Animator
FRC #1312 (Syntax Error)
Team Role: Animator
animator1 is an unknown quantity at this point
I'd like to thank MiNT for trying to help me with the question mark/exclamation mark morpher thing. But, as a beginner, this seems a little advanced. If you can think of a way for it to seem easier than great, but other than that, i will just figure a way around it i guess.
  #123   Spotlight this post!
Unread 08-02-2006, 23:40
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
bend modifer with lower or uper constraints
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
  #124   Spotlight this post!
Unread 08-02-2006, 23:52
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
Well i tried and this is what I got now to just light the room right.
Now the room I am trying to get everything lighted without turning up teh intensity of the omni light. Can't get the mental ray shadows to work right so i wne t with raytrace and they work to teh most part and tehre is 3 omni lights in teh scene any thing need to be fixed Other wise its time to animate and render.
Hear about the cannibal that passed his brother in the forest.
  #125   Spotlight this post!
Unread 09-02-2006, 02:06
MiNT MiNT is offline
AKA: oj
None #1489 (Blood Sweat and Gears)
MiNT is an unknown quantity at this point
animator - here is a simple .max with (from left to right in the scene). Drag the time slider back and forward to see them change from question mark to a line.
www.majestic12.modnmod.com/crew101/MiNT/Q.max
1. A simple line, created with create->shape->line, and i clicked 5 times.
2. The same line. I went into vertex subobject mode, selected all the vertices, right clicked, and clicked 'Bezier' (its in the top left of the quad menu that comes up when you right click in the viewport). Now that they're bezier curves, you can rotate and scale them. When you rotate, the green handles come up showing the direction that the line goes through them - the tangent. You can use the manipulator just as you normally would to change the direction. Also, you can scale the point, which lessens the degree of the curve.
3. The reference question mark
4. The bezier question mark, with 'renderable' checked, 4 sides, adaptive interpolation.
5. Just a copy of (2)...
6. A segmented box with a pathdeform modifier, using (5). The box will 'morph' around whatever path it is using, in this case, the animated spline. I also animated the y scale so the line matched up.
To animate the splines, easily, just turn on AUTO KEY (next to the key button on the bottom). I started out by keying frame 0, which is the question form. Then I went to 100, and made all the points straight, and rotated their tangents vertical. After, I went to the intermediate points (frames 50 and 75 int his case) and just rotated/moved points around until the transition was decently smooth. Whenever you change something with auto key on, a keyframe is added automatically at whatever frame you are at.
  #126   Spotlight this post!
Unread 09-02-2006, 02:12
AKA: oj
Heh, was about to say add some shadows, but I see you were already all over that =] As for the dark areas, you can safely lighten them by making an omni, setting it to diffuse only (uncheck specular), and excluding everything but the object that needs to be lightened. Then just position it however you'd like, adjust brightness, etc. Also you could perhaps add an omni, with 'ambient only' checked, at a low intensity. Keep in mind it will add with your other lights, so be careful you don't get any blowout.
For your wood materials, I would add a bit of a specular component - not too high, and with some glossiness, assuming this would would be coated. The, select the outside edges, and give them a small chamfer - this will let the corners catch a small highlight that will add a lot of depth to the scene.
  #127   Spotlight this post!
Unread 09-02-2006, 21:05
animator1's Avatar
Animator
Team Role: Animator
thanks for the file MiNT, but was it created in 3ds max 8 because i can't open it in 3ds max 7.
  #128   Spotlight this post!
Unread 09-02-2006, 21:19
AKA: oj
Ah, didn't realize that you were working in 7. I'll make another copy in 7 once I finish up hw...(it'll be there friday for sure).
  #129   Spotlight this post!
Unread 09-02-2006, 22:04
animator1's Avatar
Animator
Team Role: Animator
ok, thanks. sooner the better. hoping to upload saturday.
  #130   Spotlight this post!
Unread 09-02-2006, 22:57
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
I actually like teh shadow areas give it a little depth and I dont think I am going to do put lights in the shaded areas just exclude them from certain omnis. I will try waht you said about teh wood.
  #131   Spotlight this post!
Unread 10-02-2006, 01:46
AKA: oj
updated for max7:
  #132   Spotlight this post!
Unread 10-02-2006, 16:44
darkstar's Avatar
darkstar darkstar is offline
Animator
FRC #0585 (Warrior Robotics)
darkstar is an unknown quantity at this point
Send a message via Yahoo to darkstar
Do you guys know if tou are allowed to edit the animation forms at all?
  #133   Spotlight this post!
Unread 10-02-2006, 19:25
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Nope because then it will change the date on when teh papers when they were posted on streamline, so taht will probably disqualify u. I dont know though but I highly doubt you can change them.
  #134   Spotlight this post!
Unread 10-02-2006, 20:28
darkstar's Avatar
Animator
alright thanks, because we were thinking of putting some music in, but now we are most likely not.
  #135   Spotlight this post!
Unread 11-02-2006, 20:12
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Just clearifying on rendering, if I have teh camera just moving and nothing else important or text I dont have to set up teh safe mode or is that just a guideline? I am going to render these into tga format and use premier to put together. And then from tehre do I compress it and format it to quicktime and dv-ntsc?
Animation Question Velaes 3D Animation and Competition 15 02-02-2005 00:11
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
