Go to Post This thread is so done I can almost smell the burnt. - Chris Fultz [more]
Unread 08-02-2006, 23:13
crossedheart's Avatar
crossedheart crossedheart is offline
Resident Female
AKA: Katherine
FRC #0753 (High Desert Droids)
crossedheart is an unknown quantity at this point
Send a message via AIM to crossedheart Send a message via MSN to crossedheart Send a message via Yahoo to crossedheart
Grabbing Tilt Angle?
Ok so my question is this: How can we grab the tilt angle from the camera as a variable that we can use in the user_routines.c? Has anyone done this?
Unread 08-02-2006, 23:39
Re: Grabbing Tilt Angle?
If you are using the KOP gimbal then
TILT_SERVO is probably what you are looking for.
Just
#include "tracking.h"
in user_routines.c
Unread 08-02-2006, 23:41
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
if you're using the Kevin Watson code that places the tilt servo on PWM1, you can simply read the value of pwm01, but it has also been #defined as PAN_SERVO for more intuitive readings. In the file tracking.c, you'll see a section of the code that starts with a comment "// y-axis/tilt tracking code"
you can see how the tracking.c uses it.
But at any rate, it won't really give you an angle, so much as the position of the servo which is a number between 0 and 255, looking that up to an angle is either some scary math which might not be consistent with anyone else's based on how you installed the servo horns onto the servos. I would recommend just echoing your tilt value to the console with a printf and moving the camera until you determine what PWM value represents the angle you want.
Unread 09-02-2006, 00:58
Kevin Watson's Avatar
La Caņada High School
FRC #2429
There is a simple expression in terminal.c that will convert from PWM units to degrees. It's explained further here: http://www.chiefdelphi.com/forums/sh...41&postcount=3
-Kevin
Kevin Watson
http://kevin.org
Unread 09-02-2006, 01:11
AKA: David Page
due to the installation of the servo to the bracket, is there any guarantee that 0 degrees will actually be horizontal?
-Kevin
Unread 09-02-2006, 01:35
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
There is no guarantee, you should measure it. We measured our camera mount last weekend. Servo values of 127 (zero degrees) did not center the camera to the mount. There may also be a difference between your mount and your bot.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 09-02-2006, 02:09
FRC #0957 (WATSON)
Are those tilt angles, by themselves, accurate enough to use for aiming on your particular bot? This is an interesting question to consider. To answer it you need to read the tracking code to see what it is really doing. Look for what "locked" really means. Then some math is needed to calculate accuracies.
To answer the question you will need the following info which is not documented in the source code. I found it after searching the forums.
  • T_Packet_Data.mx = X pixel of the target centroid
  • T_Packet_Data.my = Y pixel of the target centroid
  • Horizontal camera field of view = 44 degreees (someone calculated this but I would verify it experimentally)
  • Vertical camera field of view = 34 degreees (someone calculated this but I would verify it experimentally)
Unread 09-02-2006, 03:08
Calvin Calvin is offline
Calvin has a spectacular aura aboutCalvin has a spectacular aura about
What we did was set both values to 127... than while the servos were on, adjusted the camera mount (those + thingys on the servos actually) to center both the TILT and PAN.
Camera angle - interesting question TEAM1949 Programming 3 08-02-2006 22:20
Nerf ball starting at 12m/s 45 degree angle ending at 8ft 6in w/ air resistance Ethulin Technical Discussion 39 14-01-2006 19:04
Viewing Angle of Camera Joe Johnson Technical Discussion 10 14-01-2005 14:11
Calc. Triangle Angle or Side Based on Ellipses? indieFan Math and Science 1 07-06-2004 21:25
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
