Go to Post Heaven forbid. A hexed Vex. - Warren Boudreau [more]
Unread 09-02-2006, 09:01
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Favor to ask re: dashboard
In this thread Don Reid found what he believes is an error in the dashboard spec published by IFI. http://www.chiefdelphi.com/forums/sh...85&postcount=1.
I realize that the build season is coming down to the wire, but if someone has five minutes to validate his results I would really appreciate it. This software http://www.chiefdelphi.com/forums/pa...le&paperid=593 has been downloaded 87 times. If you are able to do me this one favor you'll earn my gratitude.
In the default code, replace Process_Data_From_Master_uP() with the following code, the download it to the robot controller and run it. The dashboard should display 111, 122, 133, 144, 155, 166 for the user bytes.
void Process_Data_From_Master_uP(void)
	Getdata(&rxdata);
	Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
 	pwm01 = pwm02 = pwm03 = pwm04 = 127;
	pwm05 = pwm06 = pwm07 = pwm08 = 127;
	pwm09 = pwm10 = pwm11 = pwm12 = 127;
	pwm13 = pwm14 = pwm15 = pwm16 = 127;
	User_Byte1 = 111;
	User_Byte2 = 122;
	User_Byte3 = 133;
	User_Byte4 = 144;
	User_Byte5 = 155;
	User_Byte6 = 166;
	Putdata(&txdata);
Dashboard Programs? EHaskins Programming 5 31-01-2006 14:01
Getting Dashboard data in OS X 10.4.4? Billfred LabView and Data Acquisition 3 28-01-2006 15:02
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
Dashboard for .NET seanwitte Programming 8 16-02-2005 10:09
New dashboard packet spec Ameya Programming 2 08-01-2004 19:59
