Go to Post Thankfully, no magic smoke was released during the making of these photos. - SteveGarward [more]
Unread 09-02-2006, 13:18
blue_crew blue_crew is offline
MADTOWN ROBOTICS!!
AKA: Daniel Sheeter
FRC #1323 (Madtown Robotics)
blue_crew is on a distinguished road
Send a message via AIM to blue_crew Send a message via MSN to blue_crew Send a message via Yahoo to blue_crew
Mounting the Gear Tooth Sensor???
My team needs some help mounting the gear tooth sensor on the kit transmission. We have the wires soldered and ready we just need to know how to mount it. If someone has a pic or something that would be great! Thanks.
Unread 09-02-2006, 13:23
Re: Mounting the Gear Tooth Sensor???
Copied from this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=43413
Originally Posted by Joe Ross
You can see a suggested mounting place inside the kit transmission on page 24 and 25 of the FIRST Guidelines, Tips, & Good_Practices document. http://www2.usfirst.org/2006comp/oth...ices_Rev_C.pdf
There's lots of other useful info in that document too
Unread 09-02-2006, 13:40
MADTOWN ROBOTICS!!
AKA: Daniel Sheeter
We have looked at this and the picture isn't very clear about which gear it needs to be near, which washers are used, how the wires run out of the transmission, etc. Does anyone have a detailed picture or diagram?
Unread 09-02-2006, 13:53
"Pre-drilled mounting holes for the Gear Tooth sensor module on the transmission covers, and using the GTS hardware supplied in the kit of parts will make installation particularly easy."
It doesn't go next to a sprocket. It goes next to the gear with the pre-drilled mounting holes beside it. The big thick plastic washers go under the board; the small thin plastic washers go above the board. You can see that if you look closely at the picture.
Run the wires out wherever it makes sense for the way you have it mounted to your chassis, taking care not to run them in the way of gears, sprockets, chains, etc.
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
