Go to Post Now, everyone knows that Oompaloompas are like bunnies in that they have an insatiable desire to multiply, and the same can be said with Michigan teams (with all due respect) which are currently multiplying and filling that hand-shaped democratic kingdom with their honorable number. - Eugenia Gabrielov [more]
  #31   Spotlight this post!
Unread 09-02-2006, 16:14
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Re: Working with Lexan
Originally Posted by greencactus3
very helpful. do you want to share those skills?
Are you talking about acrylic or polycarbonate? They are two different creatures. Its like talking about tube vs pipe both are steel but they have different properties. Polycarb (or lexan) is fairly easy to work with. Just make sure you use some kind of lubricant (WD-40 was suggested) and watch that you don't start melting the plastic instead of drilling it.
If you are working with acrylic every time you try to drill it, bend it, or screw into it you are risking it cracking if not shattering. Acrylic was not allowed for use on FIRST robots for a while because of this. Personally I don't know why they changed the rule. Acrylic can be dangerous if you do not know what you are doing. Because of this we do not allow it on any of out robots or even in the shop.
If you can help it just stay away from the stuff. You guys will be much happier with the results you get from working with polycarb.
Kirk
Sources for Delrin and Lexan stock sanddrag Technical Discussion 3 04-12-2005 00:25
Who is working on their team site over the summer? Timothy D. Ginn Website Design/Showcase 15 07-06-2005 18:47
IR Beacon/reciever not working... still... Ferazel2001 Programming 23 04-02-2004 23:30
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
Whose working this summer? Frank(Aflak) Chit-Chat 20 28-05-2003 11:35
