Go to Post Don't over analyze every possibility. Studying a problem too much doesn't help any more than not studying it enough. - dlavery [more]
Unread 09-02-2006, 17:29
caderader's Avatar
caderader caderader is offline
caderader
#1284 (DART)
caderader is an unknown quantity at this point
GTS code Problems
I've been working on and revising the geartooth sensor autonoumous code for a few days now but no matter how I change it the code won't work. If anyone just has a quick example of working gear tooth sensor code it would be very helpful.The code that i'm using right now with Kevin's FRC code is right here...
void User_Autonomous_Code(void)
  /* Initialize all PWMs and Relays when entering Autonomous mode, or else it
     will be stuck with the last values mapped from the joysticks.  Remember,
     even when Disabled it is reading inputs from the Operator Interface.
  pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
  pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
  relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
  relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
  relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
  relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
i=0;
Cnt_L=0;
Cnt_R=0;
Total_Count=0.0;
Total_Count_R=0.0;
Total_Count_L=0.0;
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
      pwm01=pwm02=170;
pwm02=255-pwm02 ;
pwm01=170;
pwm02=170;
	Cnt_L=Get_Encoder_1_Count();
		Cnt_R=Get_Encoder_2_Count();
if(i<5)
			Total_Count=(Cnt_L+Cnt_R)/2;
			if (Total_Count>50)
	   			i++;
	   			Total_Count_L+=Cnt_L;
       			Total_Count_R+=Cnt_R;
       			Reset_Encoder_1_Count();
       			Reset_Encoder_2_Count();
       			Cnt_L=0;
       			Cnt_R=0;
		if (i=5)
			i++;
			Total_Count_L+=Get_Encoder_1_Count();
			Total_Count_R+=Get_Encoder_2_Count();
			pwm01=100;
			pwm02=160;
		if (i>=6)
			i++;
			pwm01=127;
			pwm02=127;
 /* Add your own autonomous code here. */
        Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
I've definedTotal_Count, Total_Count_R, andTotal_Count_L as Float's.
Cnt_L, and Cnt_R as Long's.
and i as an int.
Thank You in advance
Unread 09-02-2006, 18:11
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: GTS code Problems
Originally Posted by caderader
I've been working on and revising the geartooth sensor autonoumous code for a few days now but no matter how I change it the code won't work...
It would be helpful if you could describe what you want the code to do, and what you observe when compiling/linking/running it.
Unread 09-02-2006, 18:17
caderader's Avatar
caderader
#1284 (DART)
pretty much right now I'm trying to use a sample code to let the robot run for a certain number of gear counts(the exact number doesn't matter right now) and then after that time change the direction for another number of gear counts and then stop the robot. This should work as far as I can tell with the way I have the code but I can't right now when running the code the robot does NOTHING at all. This is very confusing so any help at all would be appreciated. If i can not make the gts work I'll be forced to use dead reconing...ughhh.
Unread 09-02-2006, 18:33
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
I think the main reason it is doing NOTHING is that you have a misplaced closing brace. As your code stands now, your putdata() call is inside the "if (i>=6)" braces. You will need to add a "}" before /* Add your own autonomous code here. */, and get rid of one at the end of the routine.
I haven't digested the whole thing yet, but that might get you started.
Unread 09-02-2006, 21:08
caderader's Avatar
caderader
#1284 (DART)
Thank you very much. I'll try that tommorow when I get time to test on the robot.
Unread 13-02-2006, 16:37
caderader's Avatar
caderader
#1284 (DART)
Still no movement or response. Thanks though.
Unread 13-02-2006, 17:01
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
pwm01=pwm02=170;
pwm02=255-pwm02 ;
pwm01=170;
pwm02=170;
there seems to be a contradiction in there...
first you set pwm02 to 170, then to 85, then to 170 again... maybe clean that up?
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 13-02-2006, 19:14
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
OK. I took another look at the code you posted before. Here it is again, prettified, and with the change I suggested before (It's a lot easier to read code with proper indentation ):
float Total_Count, Total_Count_R, Total_Count_L;
long Cnt_L, Cnt_R;
int i;
  i=0;
  Cnt_L=0;
  Cnt_R=0;
  Total_Count=0.0;
  Total_Count_R=0.0;
  Total_Count_L=0.0;
      pwm01=pwm02=170;
      pwm02=255-pwm02 ;
      pwm01=170;
      pwm02=170;
      if(i<5) {
        if (Total_Count>50) {
          i++;
          Cnt_L=0;
          Cnt_R=0;
      if (i=5) {
        i++;
        pwm01=100;
        pwm02=160;
      if (i>=6) {
        i++;
        pwm01=127;
        pwm02=127;
And here's my analysis:
You set "i" to 0 on every call to User_Autonomous_Code, so "i" is guaranteed to always be less than 5. (If it were not for the fact that your putdata() call was within the (i>=6) block, you still should have seen SOME movement, since you set your PWMs outside of the if statements.) I guess you probably want something like:
  static int i=0;
  static float Total_Count_R=0.0;
  static float Total_Count_L=0.0;
  long Cnt_L=0;
  long Cnt_R=0;
  float Total_Count=0.0;
etc.
This will initialize the variables at compile time only, rather than on every call. If you make these changes, and still get nothing, I would ask: Are you actually in autonomous mode, and is this routine actually being called?
Unread 13-02-2006, 19:23
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
In order to get into autonomus mode you need to jumper two pins on the OI's competition port. Which pins are specified in the manual.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Gyro Code Problems railerobotics Programming 8 27-01-2006 10:45
Code problems doyler Programming 14 15-02-2005 16:23
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
