Go to Post By inviting engineers and mentors to be a part of your team and partnering with them...brings added value, depth, strength, expertise, and wisdom to the team and to the overall experience. - JaneYoung [more]
Unread 09-02-2006, 18:34
Joining the 900 Meme Team
FRC #0079
Re: Feathers using hair
Originally Posted by Capt.ArD
at this point of the game, i would just go with a really high-res bump map or displacement map. saves a lot of time/anger.
if you Really want to use hair, good luck. i tried it a few times, but the objects i was using as hair stood at wierd angles and all. even if i took off the frizz from the hair, they were still rotated all over the place.
when you choose the object to use as your feather, make sure the pivot point is located near the bottom. that way, it will be more likely to align properly. also, turn down the hair segments and completely remove frizz and kink.
good luck. this hair and fur thing is pretty cool, but right now it seems to be really buggy, and doesn't like working correctly. maybe in max 9 it'll be better...
Edit: w007,/\/\y 116th p057!111!!!!!!11!
Thank you for the reply. Due to a lack of time the animation has been put on hold until this summer when i wil finish it and submit it for next year. Ill play with the hair and if i get anything ill post it here... though if anyone has any good ideas that will save time please still post them...
Hair and Fur in MAX 8 Nuttyman54 3D Animation and Competition 20 14-01-2006 14:38
What color should MY hair be? Wetzel Chit-Chat 77 29-03-2002 20:01
What color should me hair be?? AdamT Chit-Chat 6 31-01-2002 19:53
need advice, should I dye hair for kickoff? Ken Leung Rumor Mill 14 05-01-2002 18:27
ken leung's hair Ken Loyd General Forum 0 08-11-2001 08:41
