Go to Post FIRST is like Starbucks coffee, it's addicting and you just can't seem to get away from it... - Beth Sweet [more]
View Poll Results: What is your defense?
Defense, who needs a defense when you have an amazing offense. 32 26.67%
Blocking is our specialty... no shooter is safe 6 5.00%
Pushing all the way... 15 12.50%
Pushing and Blocking, we will stop anything and everything, with whatever method is needed. 67 55.83%
Voters: 120. You may not vote on this poll
Unread 09-02-2006, 18:39
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Re: Defense: Pushing and Blocking
http://www.chiefdelphi.com/forums/sh...8&postcount=41
This was a nutty idea had in the beginning. Longshot at best as stated but a dumbed down version could easily be at home an alliance with 2 Mass Shooters.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 09-02-2006, 20:57
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Last year our team perfected the art of being defensive, while still scoring major points. This year our robot is more of a tank and should have twice the torque of last year, so we'll have plenty of pushing power if need be, and the capability of holding around 50 or so balls, so score a few easy points, then push some guys around.
I'm still pushing for the pneumatic lift system. Basically like a car with an air-ride or hydraulic suspension. Build the drivetrain on a small frame, and build the rest of the robot on a seperate frame, over the drivetrain frame, supported by pneumatic cylinders. when you get where you want to be and aim, let the air out of the pneumatics, and set the actual frame down on the ground and pull the wheels off the ground. just be sure not to have the edges tear up the carpet. with all the weight, it would probably be pretty tough to push it a little. I want to build something like this in the offseason this year.
ohhohh i remember i had a picture of a chevy s-10 doing this, on air ride suspension, mono-leafed in the rear. It lays frame an pulls the wheels off the ground. i'll try and post it later tonight or tommorow...i have to find it....
Unread 09-02-2006, 21:02
CraigHickman
Posts: n/a
Our defense is simply pushing. With our wheels, and our 2 speed, we can race up to an opponent, and push just about anyone across the whole field. If somone is out of range, they can't score, correct?
Unread 09-02-2006, 21:39
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Where's the "We could go either way" option?
we have a multi-speed transmission, and should be able to push fairly easily. I've noticed a number of robots using casters, holonomic or omni wheels, which could prove very easy to push. We intend to test different strategies and go with what works best.
Unread 09-02-2006, 21:45
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
We will be able to block low shooters, but out emphasis will be on pushing
Unread 09-02-2006, 21:54
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
We'll be able to push pretty much anybody... I hope and we SHOULD have a functional launcher by ship, So We didn't have to sacrifice anything. At least I don't think we did
Unread 09-02-2006, 23:11
TEAM456MS TEAM456MS is offline
FRC #0456
TEAM456MS is an unknown quantity at this point
We will be able to push anybody in our way.
Unread 10-02-2006, 08:08
bobotics319 bobotics319 is offline
AKA: Andrew Levasseur
FRC #0319 (Bobotics)
Team Role: Communications
bobotics319 is an unknown quantity at this point
Bob can do pretty much anything... we have a strong frame and a strong offense....so pretty much bob is the man!!
Unread 10-02-2006, 09:49
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
By the results of the poll thus far it seems as though there are allot of teams out there that are unstoppable. Well I guess we will just have to wait and see how many of these robots can actually live up to their names. Torque is nothing without traction. I just don't see the necessity of being uber defensive. My belief is that offense wins championships, defense wins matches. A defensive robot can hound a robot all it wants, but if that robot can score one point than that is all that is needed to win.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 10-02-2006, 11:11
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
We chose to sacrifice a ball shooter for a good, strong drive train.
On the pushing more than one bot at once, I reckon that if they (being the said bots to be pushed) had omni wheel drives, then we could push all of them without any problem. The bots with drive trains similar to ours are going to be a little more difficult.
On the blocking, our bot isn't going to be tall enough to stop a shot from a robot with a five-foot tall shooter, but they might have problems getting off an accurate shot while they are being shoved around the field.
That said, I think that we are going to live up to our traditional reputation of being "defensive specialists" Anyone remember last year's model with the wheelie bars that <accidently, sort of> served as wedges? (we didn't design them for that, I promise.)
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
Unread 10-02-2006, 17:46
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
How can a majority of the teams have a transmission with above-average pushing power?
It's like the statistic that says a majority of drivers [for cars and trucks] think that they are above-average drivers.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-02-2006, 18:40
occra 23.
AKA: ryo
None #1481
oh man, a robot that lays frame. us minitruckers will LOVE to see this. a couple titanium dragblocks and then you'd have a LOT of fun at night too.
monoleafed air ride is bad. nice 5links and stuff is mucho better for the truck.
for pics of s10s dragging and laying just browse the s10forum.com
Unread 10-02-2006, 21:56
Nuttyman54's Avatar
Mentor, Tactician
well what is considered "average pushing power"? i think a lot of teams (including mine) overestimate the amount of actual power their drivetrain has, and that is responsible for the statistic
Unread 10-02-2006, 23:19
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
would winning a pushing match against the year's before, which happened to be unbeatable in puching matches overestimating... what I am getting at is test on how well it does against previous years (unless you are a rookie team) it will give you a general idea of greatness
Unread 11-02-2006, 00:37
Nuttyman54's Avatar
Mentor, Tactician
Excellent standard. unless the challenger has a really weak drivetrain, you should be able to get a reasonable idea of how good it is.
[moderated]: A Challenge: YOU Rewrite G25 Tom Bottiglieri General Forum 10 30-03-2005 21:18
blocking the ramp Jacqui Sutton General Forum 3 07-01-2003 09:02
