Go to Post FIRST is like we have traveled to the future, and we dont like what we saw when we got there. So we came back and now we are attempting to alter the future - KenWittlief [more]
Unread 09-02-2006, 19:49
TECHMAGE TECHMAGE is offline
TECHMAGE is an unknown quantity at this point
Banner Optical Sensors?
Some body PLEASE helps us we're trying to find the a wiring diagram or something to see how we can wire the little yellow banner optical sensors to our robot so if anyone has anything on it please get back to us at earthsuad5@aol.com or auron06@gmail.com.
Unread 09-02-2006, 21:40
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Banner Optical Sensors?
On the banner sensors, there should be four wires: blue, brown, white, and black.
Brown wire is positive source, <EDIT> between 10V and 30V </EDIT>
Blue wire is ground
Black and white wires are the signal wires
When using the black wire as your signal pin, your default value is normally closed (0 when unblocked). If using the white wire as your signal, it is normally open (1 when unblocked).
Hope this helps,
Unread 09-02-2006, 21:56
Isn't there a wiring diagram on the side of the sensor itself?
Unread 09-02-2006, 21:58
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Yes, there is, but not on each sensor, and also, it isn't very clear.
Unread 09-02-2006, 22:32
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Brown wire is +5
Blue wire is ground
Hope this helps,
I'm pretty sure they are 10-18v, not 5. We have them hooked up to a 20A fuse, and they are working fine off 12v. You *really* need to go find the spec sheet though.
Unread 09-02-2006, 22:45
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Sorry about that, instead of writing power source, I accidently wrote +5, the sensors themselves are actually rated for 10V-30V, though we have them running fine off a 9V battery.
I edited my previous post
Encoders vs. Hall Effect vs. Banner Sensors Jeff Waegelin Electrical 7 03-08-2005 10:55
Wiring Banner Sensors ten3brousone Electrical 1 17-02-2005 03:16
Optical Sensors Used as Encoders? uvabrad825 Technical Discussion 22 03-05-2004 13:22
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
