pic: Top Gun With Wheels
Re: pic: Top Gun With Wheels
wow! Very nice chassis, everything strong, sturdy, and...SHINY!!!
that's going to be a beast on the field, but how much does it weigh? |
Weight: the raw frame is reported to weigh 15 pounds. The wheels and axles add another 16 or so (I am starting to respect the "small wheel" faction) and the electronics board about a pound. That's 32 pounds as it sits. The official weight spreadsheet shows it weighing about 60 pounds with motors, gears, and chain, but without electronics and the shooter mechanism. Fortunately, the sweeper/shooter is very simple and pretty lightweight. It should come in fine, but it will probably weigh a little too much. Last year, we had to shave 20 ounces at weigh-in.
At least one of mentors doesn't want to add bumpers because he doesn't think we need them. I want to add bumpers because, well, they're free and might preserve our wheel-shaft ends from damage. |
Hmm... judging from the wheels, you are going for the ramp. Also, the indentaton in the chassis to the rear suggests you are attatching a vertical belt system? to get the balls to your shooter.
Nice strong chassis, but bumpers are probably a good idea. ![]() |
1. Ramp climbing for sure. 2. Single-wheel over-the-top launcher mounted high on the front rail, with custom bent-back design to launch over 60-inch robots. We are using dual Skyway 8-inch KOP wheels with lexan wheel covers to launch. 3. Vertical belt lifter on rear (drive backwards to load, frontwards to shoot). 4. Quad-CIMs into KOP gearboxes. 5. Big CIM drives wheel. We are running at 2:1 ratio to take advantage of motor torque curve. Lightweight wheels allow us to use step-up gearing. 6. Geared motor on lifter/loader. 7. Medium-speed motor (500rpm with gears) on sweeper. 8. Camera-driven aiming system, using either angled aimer on wheel or wheel speed (final testing TBD). 9. Lovely Blue Angel fabric on the bumpers. 10. Lots of sensors, and a really cool Navy-inspired control panel (our only sekrit wepin.) Here's the big question: should we equip the whole team with aviator-style sunglasses? |
#7
Definitely. All members should have nicknames, buzz cuts, and good tans, of course. Maverick, Ice Man, Jester... etc. I feel the need... the need for a 6 wheel drive base. Good plan. Andy B. |
#8
Wetzel |
#9
while i'm a recent convert to small wheels, i'll always have a special place in my heart for those big 'ol beadlok wheels...
i noticed that in addition to being able to slide the front/back wheels horizontally, you can also slide the middle wheels up and down. did you do this so that you could tension the chain? and if so, why not slide the gear boxes? |
#10
Our best driving robot we've ever built so far had 4 Skyway 9x2 wheels turned down flat. That foam rubber tread drives nice on carpet. I would recommend turning the tread profile flat though. From the factory, they have a pretty small contact patch. |
#11
#12
I swear I'm going to print some business cards with "MS Mech Eng" on them just to get some cred around the shop... |
| pic: 108 Gun Teaser | carlos_polit | Robot Showcase | 8 | 04-02-2006 02:46 |
| pic: Team 980 taking it to the top | Joe Domingo | Robot Showcase | 15 | 15-03-2005 00:17 |
| pic: 322 trick wheels complete | dan 322 | Robot Showcase | 7 | 21-02-2005 18:41 |
| pic: 222's wheels | CD47-Bot | Robot Showcase | 14 | 11-12-2003 08:14 |
| pic: Team #910 Top View | CD47-Bot | Extra Discussion | 7 | 06-03-2003 12:41 |
