Go to Post An annoyed inspector is a thorough inspector! - Jon Stratis [more]
  #31   Spotlight this post!
Unread 01-02-2006, 18:21
Price Vetter's Avatar
Price Vetter Price Vetter is offline
AKA: Electrical_Fire
FRC #0418 (LASA Robotics)
Team Role: Electrical
Price Vetter is an unknown quantity at this point
Send a message via AIM to Price Vetter
Re: 2006 Motor Specs
I have searched for this years fischer price motor's (not the big CIMs) pitches and can't find them. Does anybody know what it is?
Also measuring motors with strobes is VERY subject to aliasing.
  #32   Spotlight this post!
Unread 01-02-2006, 18:29
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by petek
Basic specs on all the motors are in
FIRST Guidelines, Tips & Good Practices. Glad I went looking for this because FIRST posted a new revision.
Basic specs is correct, mostly power, torque, no load RPM and current draw. What I am looking for on the van door motor is the mounting hole layout and thread size and pitch. I know the output shaft is 11mm in diameter, this leads me to believe the mounting holes are metric as well.
  #33   Spotlight this post!
Unread 01-02-2006, 20:39
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
I don't think I've seen a manufacturer's dimensioned drawing of this motor anywhere but if you go to FIRSTCADLibrary, Ed has it modeled on the Motors page. He doesn't have the threads spec'ed, and appears to have used inch units, but at least the hole circle is there. I believe you're correct about the metric mounting holes (M6?), anyway.
Pete Kieselbach
  #34   Spotlight this post!
Unread 01-02-2006, 21:10
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
There is no question mthat the ounting holes are M6. I am 100% certain on this.
Also, I am 99% that the mounting pattern is the same as it has been for every van door motor that has been in the FIRST kit (i.e. the bolt circle radius is the same).
Joe J.
Team #88, TJ2
  #35   Spotlight this post!
Unread 01-02-2006, 21:24
President, VEX Robotics, Inc.
Joe is correct, the mounting pattern is the same as the last few years. The screws are M6.
  #36   Spotlight this post!
Unread 02-02-2006, 21:26
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Spencer295
Richard because your test results vary so drastically from the specs on previous posts on motor wattage, would you mind testing the old cim motors on your dyno so I can make an accurate comparison.
I finally got my hands on an old CIM motor, to measure speed and current vs. torque on my dynamometer. [N.B.: had to order some spares in case the team burns one up testing.]
Your suspicion that my measurements are low compared with published specs is correct: I measured peak power about 270 Watts (c.f. 337 published) at about 2700 RPM, drawing 50 Amperes.
There are several reasons my measurements might be low, but accurate dynamometer torque calibration is not one of them. The most likely (IMO) reasons are (1) I let the terminal voltage drop off at higher current draw due to lead resistance, about 5 ft. of 10 qmm (~7 AWG) for each lead from the supply terminals to the motor lead connection point, and (2) I let the motor get hot while taking readings. Imperfect shaft alignment and residual drag torque in the magnetic brake probably amount to about 25 Watts.
It has been my experience that the above loss mechanisms are also present, to about the same degree, in drivetrains that I have built for FRC robots.
Richard Wallace
since 2003
  #37   Spotlight this post!
Unread 10-02-2006, 03:37
Stevo Stevo is offline
I love Penguins
FRC #1717 (DP Engineering)
Stevo is an unknown quantity at this point
Ok, so I know that the spec sheets are out there on both CIM motors (FR801-005 and -001), but I cant seem to find how much current the FR801-005 pulls under NORMAL load. I saw somewhere the specs for free load and stall, but no NORMAL load. If anyone out there could shed some light on this, it would be much appreciated.
  #38   Spotlight this post!
Unread 10-02-2006, 03:45
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Normal is a relative term. The current draw varies between the free current value and stall current value as load is applied. If you have some idea of what load you're applying to the motor, you can determine the current draw using the information provided in the spec. sheets. If you don't know the load, but can measure the shaft speed (e.g., RPM), you can work backward to find the load as well.
--Madison--
...down at the Ozdust!
  #39   Spotlight this post!
Unread 02-03-2006, 19:25
Loki1989's Avatar
Loki1989 Loki1989 is offline
AKA: Mike Parker
FRC #5338 (RoboLoCo)
Loki1989 will become famous soon enough
how fast will the wheels go with 120 pounds on them if the gear boxes have all four motors in them and the wheels have a 25 in circumfrence
2017 - FRC 5338 RoboLoCo - Mentor
2005-2013 - Team 1544 - One Byte Short
  #40   Spotlight this post!
Unread 10-12-2006, 15:59
Madison's Avatar
FRC #0488 (Xbot)
Closing this in preparation for the new season.
--Madison--
PIC18F8722 - New 2006 RC MPU, 4x more program memory! kmcclary Programming 16 08-01-2006 14:22
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
**FIRST EMAIL**/Welcome to the 2006 FIRST Robotics Competition Season! Rich Wong FIRST E-Mail Blast Archive 0 06-09-2005 19:19
New Regional in Europe in 2006 unapiedra Regional Competitions 49 26-05-2005 00:07
Teaching "C" to 2006 students?? cbolin Programming 28 18-05-2005 12:10
