| View Poll Results: How does your robot interact with balls on the ground? | |||
| Specific mechanism to herd them into the lower goal. |
17 | 17.00% |
| Specific mechanism to pick them up from the ground and bring them inside the robot. |
85 | 85.00% |
| Ground ball manipulation is not in our strategy. |
13 | 13.00% |
| Multiple Choice Poll. Voters: 100. You may not vote on this poll | |||
Re: Who is picking up from ground?
There was no sacrifice when we designed our robot. The robot is designed with continuous feed in mind. The balls are picked up off the floor and placed in a hopper than runs the entire back portion of the robot. The same conveyor used to place balls into the hopper is used to feed the shooter so they can also go directly to the shooter. And that’s not all! That same conveyor is also used to feed the balls from out of the hopper and up to the shooter. This meant a lot less conveyors and a lot less weight in belting.
Koko ed, i really like your team's method of picking up balls! Looks REALLY smooth and effective! Great job!
As for 1023, we are planning to have the ability to pick balls up and contain them. We also have the ability to receive balls from the human player I don't think we really sacrificed anything to be able to do this, we all realized the importance of this feature. |
| Common Ground on Limit Switches | Gary Bonner | Electrical | 4 | 18-02-2005 13:24 |
| how important is ground clearance? | Zippiot | Technical Discussion | 10 | 16-02-2005 11:56 |
| Manipulating tetras from the ground. | Petey | Rules/Strategy | 4 | 08-01-2005 23:19 |
| Distro block, maxi fuse box, and ground stem | ErichKeane | Electrical | 25 | 20-02-2004 07:19 |
| Ground Stud | Teedoff101 | Electrical | 11 | 16-02-2004 07:20 |
