Go to Post Sometimes our greatest failures lay the foundations for our greatest success. - =Martin=Taylor= [more]
Unread 10-02-2006, 02:57
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Cat5 for Camera PWM Runs?
I was at work today thinking about tommrows task of wiring up the camera to the top of our shooter. I came up with the briliant idea of using 2 Cat5 twisted pair cables to extend the pwm runs. I want to use to to make sure i have no crosstalk, granted im pretty sure i could do all of the camera on one cat5. So what do you guys think, has anyone tried this before? theres no reason it wouldnet be illegal right?
Unread 10-02-2006, 07:10
Re: Cat5 for Camera PWM Runs?
There are two electrical rules which apply. You're supposed to observe the right color code for ground and power, and you're supposed to use at least 24 gauge wire for sensors and the like.
I've made a cable using AWG 24 ribbon cable for camera power and communication (and pwm signals to the servos).
Unread 10-02-2006, 09:46
I go along with Alan but want to add that solid wire should not be used on an object that takes as much physical poounding as a robot. It will crack and fail when you need it the most.
Unread 10-02-2006, 13:49
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Well they do make stranded cat5 cables (they're the expensive kind), but the color thing might be a problem. cat5 cables normally have blue, green, orange, and brown, as well as their striped alternatives.
EDIT; Here is the rule from the manual:
<R81> All wires distributing power with a constant polarity (i.e., except for Relay Module, Speed Controller, or
sensor outputs) must be color-coded as follows:
• Use Red, White, or Brown wire for +12 Vdc and +5 Vdc connections.
• Use Black or Blue wire for Common (-) connections.
You can use the brown wire for positive, and the blue wire for ground, and you're good to go. It doesn't say anything about not having an extra layer of insulation over all the wires.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 11-02-2006, 02:08
Rombus's Avatar
AKA: Rick Kosbab
Im probably just going to run custom wire runs for the pwms and serial/power, we have some clear heatshrink and ill just shrink it all together. I like my runs nice and neat, and i would want to use heatshrink over the outer insulation, so there would be no way to determen the color code of the cat 5 and if the robot was following the rules.
Unread 13-02-2006, 00:22
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
Well if the inspectors decided to be really thorough that probably wouldn't fly. They like to see where everything goes.
Unread 13-02-2006, 03:37
Rombus's Avatar
AKA: Rick Kosbab
you talking about clear heatshrink not flying or how i would have liked to run the CAT5 runs?
Actually, i was thinking about being even neater and using keystone jacks and making some custom straight though cables, would look even neater and easy to remove if nessicary
Inductance of CIMs phrontist Electrical 13 06-01-2006 09:17
reading hobby PWM sciguy125 Programming 2 17-10-2005 20:47
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
