Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Unread 10-02-2006, 13:16
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Re: Using 7.2v charger as BackupBattery
In the rule book there is a rule about using a different backup battery as long as it was a 7.2 volt, that means you can if possible, grab a Vex battery, which is 7.2, but has 2000 mAh, instead of the measly 600 mAh that comes in the standard battery pack supplied by FIRST.
There are also standard RC car batteries that run at 7.2 Volts, which would allow you to do the same thing.
Another option is looking for the chart to make a backup charger from the 12 volt battery, however so far my team has decided not do this as we are already abusing our 12 volt battery.
My Blog!
Problem with the battery charger Lightposter Electrical 4 19-01-2006 10:39
OH NO! I left the charger ON!!! sanddrag Electrical 11 11-03-2005 19:57
Battery charger model# ? computhief263 Programming 3 22-03-2004 13:21
Multiple Batteries from one charger Venkatesh Electrical 16 03-03-2003 23:39
6 Volt charger...? kangarue23 Technical Discussion 7 12-04-2002 10:35
