Go to Post I guess we'll just have to resort back to our original plan of telepathy. - seg9585 [more]
Unread 10-02-2006, 18:14
Dr.Bot
Posts: n/a
Re: Aim Well
Depends.
If you can pick up balls from the floor, it may be just extra weight. If you can't pick up the floor balls, and plan to reload via your human player, any advantage you can give yourselves is a good idea.
Unread 10-02-2006, 18:31
kevinw kevinw is offline
kevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to all
Re: Aim Well
Originally Posted by Dr.Bot
Depends.
Imagine you are against other bots who excel at picking them up from the floor. If picking them up is not your strength (or if the opposition is stronger), a catcher may be the most effective way to get balls to your bot.
Unread 10-02-2006, 18:34
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
ida_noeman is on a distinguished road
Re: Aim Well
It just seems to me that this doesn't seem like a competitive main way to get the balls in your robot. 1.) You can't assume that your team mate will be able to hand them off to you and 2.) How accurate really, is your human going to be? There's a big wall in front of them... and 3.) It will slow down / complicate your robot.
Just doesn't seem like a great strategy.
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
Unread 10-02-2006, 21:34
shimarikakari's Avatar
shimarikakari shimarikakari is offline
The intuitive view
AKA: Lucas
FRC #1540 (Flaming Chickens)
Team Role: Electrical
shimarikakari is an unknown quantity at this point
Re: Aim Well
I think it's mostly an issue of weight. A field loader weighs about the same as a big ball catcher. If you use both a big ball catcher and a field loader, then that's a certain amount of weight you take away from improving the shooter and the stability of the drive train. Realistically, will you ever have to collect balls using both human players and field loaders? It seems to me that you should use whichever type of loading you can build more effectively, because I doubt that either type of robot will find a shortage of ammo with eighty balls split between the goals and the field.
Knowledge turns chaos to order.
Unread 10-02-2006, 22:00
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Aim Well
we have an open hopper, but it was not designed to make HP loading as easy as possible, it's probably going to be fairly difficult to load unless it's pretty close up. but we have what should be a fairly effective collector, so we're not too worried
Unread 10-02-2006, 22:19
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
Re: Aim Well
Imagine a scenario where you have 6 effective scoring machines (low or high). This will be the case in the playoffs. In this case there could be (theoretically) almost nothing on the floor.
In this case hopper loading from close range becomes the dominant mode of ball transfer.
In 2000, 2001, 2002, and 2004 balls were already out on the floor, fired onto the floor from half court, or dumped on the floor intentionally. In a really good match in 2006, I am not so sure there is going to be that much to harvest.
Just my 2 cents.
Good luck to everyone this season!!
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
Unread 10-02-2006, 22:46
TEAM456MS TEAM456MS is offline
FRC #0456
TEAM456MS is an unknown quantity at this point
Re: Aim Well
Look for a human player that plays soccer. When you throw a ball back into play during soccer you throw overhead which mimics throwing over the wall. Our guy is dead accurate.
We Aim For The Stars Part III Ken Leung General Forum 5 03-01-2006 16:57
AIM problem Nimmy Chit-Chat 15 29-12-2005 13:24
AIM remote in a myspace Bill_Hancoc Chit-Chat 10 26-11-2005 00:28
(part II) We aim for the stars Ken Leung General Forum 6 03-05-2005 16:57
realphx.com AIM worm David Kelly Chit-Chat 0 14-10-2003 23:43
