Re: Aim Well
Just doesn't seem like a great strategy. |
Re: Aim Well
I think it's mostly an issue of weight. A field loader weighs about the same as a big ball catcher. If you use both a big ball catcher and a field loader, then that's a certain amount of weight you take away from improving the shooter and the stability of the drive train. Realistically, will you ever have to collect balls using both human players and field loaders? It seems to me that you should use whichever type of loading you can build more effectively, because I doubt that either type of robot will find a shortage of ammo with eighty balls split between the goals and the field.
Re: Aim Well
we have an open hopper, but it was not designed to make HP loading as easy as possible, it's probably going to be fairly difficult to load unless it's pretty close up. but we have what should be a fairly effective collector, so we're not too worried
Re: Aim Well
Imagine a scenario where you have 6 effective scoring machines (low or high). This will be the case in the playoffs. In this case there could be (theoretically) almost nothing on the floor.
In this case hopper loading from close range becomes the dominant mode of ball transfer. In 2000, 2001, 2002, and 2004 balls were already out on the floor, fired onto the floor from half court, or dumped on the floor intentionally. In a really good match in 2006, I am not so sure there is going to be that much to harvest. Just my 2 cents. Good luck to everyone this season!! |
Re: Aim Well
Look for a human player that plays soccer. When you throw a ball back into play during soccer you throw overhead which mimics throwing over the wall. Our guy is dead accurate.
| We Aim For The Stars Part III | Ken Leung | General Forum | 5 | 03-01-2006 16:57 |
| AIM problem | Nimmy | Chit-Chat | 15 | 29-12-2005 13:24 |
| AIM remote in a myspace | Bill_Hancoc | Chit-Chat | 10 | 26-11-2005 00:28 |
| (part II) We aim for the stars | Ken Leung | General Forum | 6 | 03-05-2005 16:57 |
| realphx.com AIM worm | David Kelly | Chit-Chat | 0 | 14-10-2003 23:43 |
