Go to Post A FIRST adage: You can make an Offensive robot play defense more effectively, than you can make a Defensive robot play offense. - Enigma's puzzle [more]
Unread 10-02-2006, 18:38
dwc309 dwc309 is offline
FRC #1552
dwc309 is an unknown quantity at this point
Talking Wireless communication during the matches
Ok, I'd like a clarification.
Definition of component
A robot part in its most basic configuration, which cannot be disassembled without damaging or destroying the part, or altering its fundamental function.
<R53> has been quoted but does not seem to apply.
<R57> The use of additional electronics is intended to allow teams to construct custom circuits for their robots.
The custom circuits may be used to indirectly affect the robot outputs by providing enhanced sensor feedback
to the Robot Controller to allow it to more effectively decide how to control the robot. In addition to the
required branch power circuit breaker, smaller value fuses may be incorporated in the custom circuits for
additional protection. All outputs from the custom circuits must be connected to the analog inputs, digital
I/O, TTL Serial Port, or Program Port on the Robot Controller.
<R59> Custom Circuits may not:
• Be used for wireless communication, such as sending or receiving a signal to and/or from the alliance
station
So, the way that I'm reading this is that a bluetooth serial port is a component that may be connected to the program port. It is not a custom part which by R59 may not be used for wireless communication.
An inquiring mind wants to know a definitive answer. What rule prohibits a bluetooth serial port from connecting to the programming serial port?
QUICK WIRELESS HELP JamesBrown IT / Communications 17 20-04-2005 02:33
How Many Seeding Matches were Played at your Regional? Don Knight Regional Competitions 36 04-04-2005 14:03
Boilermaker Regional Wireless Scouting System. Josh Hambright Regional Competitions 4 21-03-2005 19:48
Ideas for Detroit Regional Btower Regional Competitions 15 14-03-2005 20:53
Did you use the 802.11b wireless LAN at EPC@T? soap108 Championship Event 21 04-01-2003 11:03
