Go to Post It's a FIRST thing. You gots to understand. - Koko Ed [more]
Unread 10-02-2006, 20:46
dwc309 dwc309 is offline
FRC #1552
dwc309 is an unknown quantity at this point
Start timing and details
1. Are the robot controls enabled until autonomous begins?
2. Does the robot have to be driven into the competition arena or is it carried?
3. Is any reset issued by the competition referees or can it be initialized by by the programming port?
4. If not, could it be initialized prior to bringing it into the competition?
Unread 10-02-2006, 20:48
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Start timing and details
1. No, they're disabled.
2. It is carried.
3. The competition control should reset your robot at the start of the round.
Unread 10-02-2006, 21:09
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Not exactly true - if you have switches (such as dip switches) you can set them before autonomous mode. While your robot is sitting disabled on the field, you can read in the states and save them. Durning autonomous mode they will read as all disabled, but you can refer to the saved state and make decisions. We used this to select between autonomous modes. They were numbered from zero to fifteen, and you would poke in the right value onto a bank of four dip switches. Before the match, the controller would read them in and store them. During autonomous, it would then change programs based on what we had chosen.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 11-02-2006, 08:46
Sorry, Adam Richards, but you're wrong on a couple of things.
1. The robot controls are enabled. The robot outputs are disabled, but the program receives input from the OI up until autonomous mode is activated.
2. Teams carry their robots onto the field, typically setting them in place and applying power as the driver and/or operator sets the controls on the alliance station shelf. I don't know of any teams that drive to the field; most if not all have a cart.
3. I don't think the refs can cause a reset, though they can certainly disable a robot. The "robot reset" button on the OI will reset the robot if you want. You can't do a reset via the programming port in any case.
4. Usually a robot is powered off until it's brought onto the field. You may do a reset at any time before you leave it there prior to the match beginning.
Unread 11-02-2006, 10:08
FRC #1552
Talking Re: Start timing and details
Thanks to everyone for their replies.
