Go to Post In theory, this should work... Oops. - Eldarion [more]
Unread 10-02-2006, 20:39
Conan Conan is offline
FRC #1137
Conan is an unknown quantity at this point
push-button switch on robot
Hello, for autonomous mode, we were thinking about putting a momentary push-button switch on the front of the robot so we would know if we hit an obstacle (wall, robot, etc.). So, I went down to Radio Shack and picked up a button. The button (like most switches) has two leads that are connected when the button is pushed. How would be attach this to the robot controller? Doesn't the controller have three leads (power, signal, ground)? Thanks.
Unread 10-02-2006, 21:10
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: push-button switch on robot
In general, connect one leg of the switch to ground and the other to signal. The RC has internal pullups on inputs 1-6 at least - I believe for some of the higher ones you have to provide external pullups. Check the RC docs.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 10-02-2006, 21:16
FRC #1137
Thank you. I'm pretty sure we'll only have two switches, so the use of higher inputs should be unneccessary. So, for the red wire, do we just not hook it up to anything?
Unread 10-02-2006, 21:55
Nope, just make sure it doesn't touch anything
Unread 10-02-2006, 22:03
FRC #1137
Thank you very much.
Robot songs Alex Burman Chit-Chat 19 24-01-2006 08:07
[moderated]: A call for an end to inconsistency (sticking up for G25) Travis Hoffman General Forum 48 28-03-2005 14:14
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
