Go to Post Redfoo is actually a really awesome guy. He discussed the future of engineering and talked about C programming with our software team. - SM987 [more]
Unread 10-02-2006, 22:09
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Gyro not working in Autonomous?
The students and I have been banging our head on this one:
Our gyro is working fine during regular operation, but during autonmous mode Get_Gyro_Angle() always returns 0. I've even managed to reduce this down to the fairly minimal code below:
void User_Autonomous_Code(void)
  pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
  pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
  relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
  relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
  relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
  relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);
        Camera_Handler();
        Servo_Track();
        printf("%d ",(int)Get_Gyro_Angle());
        Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
        Putdata(&txdata);
Any ideas on this one? Our current bot really needs the gyro for feedback in auto mode. The camera is working fine.
Unread 10-02-2006, 22:23
Jared Russell's Avatar
Taking a year (mostly) off
Re: Gyro not working in Autonomous?
Have you called BOTH Start_Gyro_Bias_Calc() and Stop_Gyro_Bias_Calc() before autonomous executes?
Unread 10-02-2006, 22:30
kaszeta's Avatar
No, I don't, but that's because I know the bias already. I do call
Initialize_Gyro();
Initialize_ADC();
Set_Gyro_Bias(1092); //1092 for kit gyro, 1003 for ADXSR300
in my User_Initialization () function, which is called before autonomous mode triggers. And the gyro is working perfectly in user mode (indeed, if I flip back and forth from autonomous mode to user mode the gyro always works in user mode)
Unread 10-02-2006, 22:49
jaustin jaustin is offline
AKA: Jeff Austin
FRC #2930 (The Taterbotz)
jaustin is an unknown quantity at this point
We are having the same problem, see our symptoms in the gyro code sticky thread. I've also posted the code we are trying to use.
Unread 10-02-2006, 23:00
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
It's a simple problem to fix:
The call to update the gyro is preformed in Process_Data_From_Local_IO, which is not called during autonomous mode. If you copy the code for it to the User_Autonomous_Code loop, everything will work.
To be specific, this code needs to be in your autonomous loop:
if(Get_ADC_Result_Count())
    	Process_Gyro_Data();
    	Reset_ADC_Result_Count();
Took me a little while to figure that out
Unread 10-02-2006, 23:31
AKA: Jeff Austin
Smile Re: Gyro not working in Autonomous?
Devicenull,
YOU ARE AWESOME!
I was just getting ready to type a note asking why the Process_data... function might not be running in my code and there was your note! It is very confusing since I've been working with the EDU all summer and it appears to run that function during autonomous.
You're a life saver!
Unread 11-02-2006, 00:04
kaszeta's Avatar
You da man! I was just trying to piece together the ADC event loop and had done some code to make sure Timer 2 was getting called, and got this message. Thanks for saving us some significant debug time.
Unread 11-02-2006, 01:28
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I've updated the gyro documentation to make it clear that Process_Gyro_Data( ) needs to be called from User_Autonomous_Code( ). For grins, I also updated the code in frc_gyro.zip.
-Kevin
Kevin Watson
http://kevin.org
Labview used to debug the Gyro joshR515 National Instruments LabVIEW and Data Acquisition 1 09-02-2006 20:56
Autonomous robots working & interacting with each other & their environment. Elgin Clock Math and Science 0 19-05-2005 01:00
Next Years Game? Jeremy General Forum 49 27-04-2004 01:53
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
