Go to Post Part of FRC and design/engineering is perseverance. Keep your chin up, your thoughts positive, and have respect for your work and the work of your teammates. - Nathan_Fraser [more]
Unread 11-02-2006, 00:00
DonRotolo's Avatar
Back to humble
FRC #0832
Re: JB weld question...
Originally Posted by KenWittlief
I fixed a leak in the oil pan (small hole on the side) on my Fiero, and it lasted 3 years at least (I sold the car)
Funny, I used JB Weld for the same purpose, reinforcing the hole with a screw. Held up great.
JB Weld is a fairly good adhesive and an excellent filler. It has a lot of compressive strength, moderate shear, and poor tensile strength. It adheres well under poor conditions (heat, oil, chemicals) but isn't as good underwater. I knew a fellow who repaired a crackled engine block with it, that's where I first heard of it (over 20 years ago!!)
There are far stronger adhesives, like the clear stuff in a doiuble-tube syringe from Radio Shack (and others), but these are poor fillers. I recommend buying a small package and playing with it, you;'ll learn what it can and cannot do.
Hope that helps.
Don
Question of the Week!!! (8/24/04) Andy Grady General Forum 27 27-08-2004 19:00
Question of the Week!!! (7/19/04) Andy Grady General Forum 23 23-07-2004 13:21
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
Question About Welding Eric Bareiss Technical Discussion 6 03-05-2003 12:54
