Go to Post Little kids playing soccer....or a typical Lunacy match. Ah, memories. :cool: - Travis Hoffman [more]
Unread 10-02-2006, 22:40
QuantumNinja QuantumNinja is offline
FRC #1677
QuantumNinja is an unknown quantity at this point
"Hopping" With tank style turning.
Alright. Our robot is configured to have all 4 wheels being driven, two motors on each side drive each sides wheels. To steer, it obviously slows down one side, or to spin on a dime, one side goes forward, the other backwards. The problem is... the robot seems to "hop", and the motors get really loaded when turning and especially when trying to spin. We are using the IFI Robot Wheels which are extremely grippy. I notice that alot of teams steer like this... and i'd like to know how they overcome the probelm we are having. Thanks.
Unread 10-02-2006, 22:52
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Re: "Hopping" With tank style turning.
There are a couple ways to do this:
1) use less "grippy" wheels. Since the wheels will slide easier, it won't hop
2) widen your wheelbase. If a wheelbase uses 4 identical wheels like you have, and it is longer than wide, it will hop. Typically, robots that are wider than they are long will not have this problem. Note that for this purpose, you measure from where the contacts the floor.
At this point in the season, #1 would obviously be easier for you to do.
There may be other ways around this problem, but this is all I can think of off the top of my head.
This whitepaper discusses this problem and shows you how to fix it.
Good Luck!
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 10-02-2006, 23:06
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Along with Ryan's advice, many teams use Omni-wheels to make their front pair* of wheels slide laterally with ease. You will still have good front to back pushing power. Also, your resistance to getting pushed will still be good on the end of your robot where the Traction Wheels are located. You will lose resistance to being pushed sideways at omni-wheel end of your robot.
Teams have been using this technique to steer better since '98.
#: or back pair, depending on which end is carrying the most weight. You want the traction wheels carrying the heavier load.
Andy B.
Unread 10-02-2006, 23:39
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
Another option is to replace all the wheels with mecanum wheels and drive them all with seperate motors. These wheels are similiar to Omni-Wheels but have the rollers at 45 degrees making it so you can drive holonomically. This idea is probably not feasable at this stage since it took us 4 weeks to make ours last year and a lot of programming to make them work perfectly.
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
Unread 10-02-2006, 23:49
what are we up to now? Plan D?
Plan D: use different wheels on the front that are not as grippy. They will slide sideways easier. The back wheels will dominate the steering, and the front wheels will slide.
Plan E: make a pneumatic wheelie-castor that raises the front wheels off the ground using a castor and a pneumatic cylinder. When you want to turn easily you push the castor down, turn, then retract it.
Unread 11-02-2006, 00:17
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
I'm guessing it's a bit late to go to a wider frame or change the drive around.
And if you don't have the money or machine tools to get omni wheels (which are a great idea at this point for ya), then you can do the cheap fix.
Wrap the wheels on the light side of the robot in something slippery - we use rip-stop nylon zip tied onto the wheel. Heck, last year we PLANNED on using replaceable rip-stop nylon wheel covers. They worked well, and cost about $2.
Omni wheels are, of course, better if you can afford them.
Brian Graham
Unread 11-02-2006, 15:39
Jared Russell's Avatar
Taking a year (mostly) off
The pneumatic pop caster has worked flawlessly for us - you get the best of both worlds: turning on a dime, and four high traction wheels on the ground when you need them.
Unread 11-02-2006, 18:07
in between teams
AKA: Luke Van Oort
This is exactly what happened to us at VCU last year. See, with your robot's drive geometry it can't turn. What's happening is the insane torque of the drivetrain is twisting the chassis so one wheel is no longer in contact with the ground. Since that wheel now has zero traction and no real effect on turning, it becomes a 3WD that can turn. Then, the chassis flexes back, since you don't have the force to keep it up anymore, starting the cycle all over again.
Now, as to fixing it, we packed our treads with epoxy clay last year, and it worked like a charm. After a while, though, it started to crack and fall off (epoxy clay is brittle when dry), so we reapplied at the championship. It also looked way better than a bunch of zip ties wrapped around the wheels.
Team 1219: 2009 - Mentor
Unread 12-02-2006, 17:59
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
We had the same problem last year, too much traction, it seams can also be a bad thing. So we simply wrapped the two front tires in a bunch of zip ties (not the best looking) but elegant in it's suplicity. Hind sight, being what it is, you could have always gone for real grippy front or rear tires, and gone for some of thoose fancy omni wheels on the other set. Still provides great forward traction, and at the same time, allows you to turn without causing as much load on the motors and drivetrain.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 12-02-2006, 23:30
Wolf103FM's Avatar
Wolf103FM Wolf103FM is offline
AKA: Rich
FRC #1028 (Ubergeeks)
Wolf103FM is on a distinguished road
We've used zip ties all around the rear wheels before,we have also cut grooves in the tires but i don't remember if that was for traction or turning
They...Call me...... TATER SALAD
TEAM 1028
2006 Palmetto Judges Award Winner!
In Memory of Andy Underwood
Unread 12-02-2006, 23:38
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
We had that problem last year with our massive 1.5" brecoflex 4-wheel drive. This year we switched to a six-wheel drive. With the center wheels mounted about a quarter inch lower than the front and rear pairs, most of the weight is on the center wheel, which allows for insane turning, and insane traction at the same time. In fact, we just got the chassis driving last week and we were having so much fun just spinning the thing in high gear circles, something that wouldn't have come close to working last year.
So yeah, it's probably a bit late to add another pair of drive wheels to your chassis, but for next year, definitely go 6-wheel. Last year we partially fixed the problem by using the beige diamond-shaped tread on the back wheels and the super grippy black tread on the front wheels.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 13-02-2006, 00:05
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Are your IFI wheels 8"?
You could try replacing the front or back wheels with the ktibot skyway 8" wheels. Since they have less traction, this would be a quick way to experiment and see if wheels with less traction would solve the hopping problem.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 13-02-2006, 08:09
Quantum,
As you see, this is a common problem with tank style drives. The side friction causes incredible (near stall) current demands on the elctrical system and the hopping is due to a variety of factors including robot frame flexing. The best alternative at this stage (late in the build season) is to use omni wheels. A variety of types are available including the types found here. http://www.andymark.biz/plastic-omni.htm which are easily available and designed for First robot use. Once installed you will find your robot is happier, your electrical system is happier and drivers are happier.
Unread 13-02-2006, 09:46
Dick Linn's Avatar
no team (Synergy)
Try to find some wheels of the same diameter with less traction, at least on one end. Even with that, you may need to bump steer. One year, our drivers had to reverse one side and go full forward with the other in order to turn worth a darn.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 13-02-2006, 10:32
Back after 4 years off
FRC #5279
The easiest way to cut down the traction on the fron wheels without spending too much more money is to buy th pool hose (like for pool filters) and cut it in half then zip tie it to your wheels. If you want to see what i mean find pictures or 121 in 2004 and look at their front wheels. Try http://www.Joemenassa.com
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Autonomous Camera Integration GregC Programming 2 06-02-2005 14:34
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
tank or go-cart style steering? archiver 2001 17 23-06-2002 22:42
tank steering archiver 2000 10 23-06-2002 22:28
