Go to Post Given how easily these things pop, is "Blow Out Pricing" really the best choice of words? - ahecht [more]
Unread 11-02-2006, 02:16
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Re: Aluminum Wire
Stupid question time:
How will a judge be able to tell? As the electronics person on our team this is a very interesting thread, but my team is using the lightcrimp-solder-heatshrink method, and im sure the teammates use enough heatshink to cover all but the connector itself. So besides reading the wire itself, is there any external or a different feel to alu wire?
Unread 11-02-2006, 10:41
Re: Aluminum Wire
Again,
I don't know of anywhere to get aluminum wire in the size used on robots. (#12-#18) but if you do not oversize the wire, everyone will know when it smokes. A #12 aluminum wire can only handle the current a #14 copper wire can.
Barry,
I have to disagree, aluminum oxide is conductive but that is not the problem with welding. The arc in the weld area will cause significant oxidizing of the weld material and the base material. The melted material cannot bond with the oxide and therefore, an inert gas must be used to minimize oxidation. Ground rods are steel plated with copper ( commonly known as "copperweld" this is also used for antenna wire and ground bonding). You would not be able to drive an aluminum rod into the ground without bending it. (unless it was a large diameter like 1")
The mains coming into my house are also aluminum but are entering an alloy block intended for terminating aluminum wire. The wire is not coated with an anti oxidizing chemical or anything else. Often in older installs, you might find a copper sleeve placed over the wire before insertion into a terminal or panel.
Finally, there is a rather nice spell check on this board that will help quite a lot. I use it all the time.
Unread 11-02-2006, 12:14
Re: Aluminum Wire
Alumimum wire would be marked "Al" or "Aluminum"
the judge would be able to tell the same way a houseing inspector can tell - looking at the markings on the insulation.
BTW, Im pretty certain that, even though it is lighter, aluminum wire is not used on commercial aircraft.
Minimum Gauge Wire for Sensors? psquared89 Electrical 2 05-02-2006 15:26
Super flexible Wire want2modmygt Electrical 10 18-01-2006 18:39
My Wall Caught On Fire!---A Classic *Mangia* Aignam Chit-Chat 10 03-09-2004 03:27
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
Looking for aluminum wire archiver 2000 5 23-06-2002 23:48
