Go to Post It would be wise to consider the reasoning behind the statement rather than the statement itself. Sometimes they are right... other times their statement is incomplete... and other times they really do have no clue what they are talking about. - dtengineering [more]
Unread 11-02-2006, 03:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Aluminum Shifting Dogs?
For everyone who has built dog shifter gearboxes in the past, do you think 6061 Aluminum shifting dogs would work? The shifting dog is 1" OD, engages the gears .130" has a 1/2" hex, 1/2" through bore, and is in the last stage of the gearbox where it is geared down approximately 15:1 from the input of two small CIM motors. Please let me know if you think aluminum will work. Please don't respond with "I don't see why not but I have never built one before." I'm looking for a definative answer and a reason to back it up. I need to know before 9:30 AM PST today (saturday). Thanks so much.
PS. The hex shaft itself will be steel, if it makes any difference.
Unread 11-02-2006, 04:19
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: Aluminum Shifting Dogs?
6061 is a little scary. If you said you wanted to use 7075 or 2024 I might say you'd be okay (maybe!).. but there is a significant strength loss going from say a 1018 mild steel to 6061 aluminum.
How many dogs do you need? Are you having difficulties machining the steel dogs? Or is it some other reason?
If it is an emergency, I might be able to scrounge up some dogs for you to use (you'd need 4, correct?)
Let me know.
Bottomline, 6061 sounds scary.... I could do the math real quick, but the advantages of steel are numerous, much more than its strength alone.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 11-02-2006, 04:24
We were going to see if we could machine the hex, and the machinist would be happier (and could use smaller tools) if they were made from aluminum, but since a knowledgable person (Travis) is concerned, we'll just do steel. I just wanted to know if we could get away with aluminum, but I share your concern for things like wear on the hex and on the edges of the dog "fingers." If we take shallow cuts and slow feeds, we should be able to do the hex in steel. We'll just have to buy the machinist lunch.
Unread 11-02-2006, 04:33
Engineering Mentor
FRC #0254
We actually have a 1/2" hex broach at the high school if you'd like to borrow it (but no arbor press to use it with!!). Otherwise, we still haven' broached our dogs (or 100+ other parts) yet, so we would easily be able to do a handful of dogs at the same time for you guys. We would probably do everything tuesday or wednesday of next week.
Again, let me know.
What ever happened with those gears?
-Travis Covington
Unread 13-02-2006, 08:01
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
The biggest problem with aluminum will be longevity. Shifting on the fly will reduce this and the interaction during the mesh will also hurt. Lube with grease and bring spares. The issue I see is that the edges will round and/or burr causing problems during shifting. They should be fine for driving the gear once engaged.
sorry for the delay in answering, did not go on-line til this morning, something about building a robot
Andy Brockway
Team 716, The Who'sCTEKS
Unread 13-02-2006, 08:39
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
I have no experience with aluminum dogs, but I would stay away. As Andy mentioned above, the edges are likely to round. Once this begins to happen, you may see another problem occuring: the dog may be forced out of its mating gear. Dog gear interaction needs to be parrallel with the turing shaft. Any lead in our rounding acts like a cam, forcing the dogs apart while under a radial load.
Andy B.
Unread 13-02-2006, 11:14
I borrowed Travis's broach and we're doing them out of steel. But thanks for the comments everyone.
bolting square aluminum without crushing walls greencactus3 Technical Discussion 11 20-01-2006 16:58
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
A funny story involving 80/20 Aluminum! Rombus Chit-Chat 1 12-04-2005 00:44
Shifting Transmission rmmlg Technical Discussion 5 25-12-2004 00:05
Difference in aluminum archiver 2001 1 23-06-2002 23:49
