Go to Post There is no MILSPEC standard for pool noodles. - Rick TYler [more]
Unread 10-02-2006, 22:50
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Durability of Vision Target
We accidentally left our vision target on for about 6 hours today, and we also accidentally hit it with a launched poof ball a few days ago. Soon enough today, we realized that the cathodes in the box weren't aligned in parallel anymore.
Well, we got it down, and we discovered that the heat from leaving it on so long combined possibly with the shock that it sustained a while back has caused some of the ahesive to... become somewhat melted. So, I was there trying to realign a bunch of hot cold cathodes that had their ends covered in molten adhesive.
Anyone else had this problem yet? And what's this situation going to be like when the competitions roll around?
Unread 10-02-2006, 22:59
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Durability of Vision Target
Yes, we have that problem.
We just left them all crooked; it shouldn't make a difference.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 10-02-2006, 23:20
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
We noticed when we were testing the camera and left the light on that the plastic started to melt but simply stopped it then to prevent the further meltage.
I have no idea how they're going to deal with it at the regionals... at best the color isn't effected but they'll have to change it out sometime or another.
"Relativity applies to physics, not ethics." Thank you Einstein
MIT '10
Proud Member of H.I.L.
The PLATINUM DRAGONS are on FIRE!
Unread 10-02-2006, 23:38
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Balls hitting it shouldn't be a problem. We've hit our light with at least 10 balls already.
I don't know how much the heat will effect it. Ours is built inside a cardboard box and aluminum foil.
Unread 10-02-2006, 23:56
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Some how ours fell of a shelf I really didn't understand how ??!?!??!
So had to buy new tubes. $80.00
Unread 11-02-2006, 00:02
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Isn't there supposed to be a fan in the vision target box?
I assume those of you who are having heat problems aren't using such a fan?
2001-2004: Team 100
2006-Present: Team 254
Unread 11-02-2006, 00:12
Michelle Celio's Avatar
Michelle Celio Michelle Celio is offline
dream. belive. accomplish.
Michelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond repute
We had our box on for about an hour, but then again we attached it with hot glue, but it all just like fell. It is now held to gether with Duck tape and Zip Ties
UCF History & Education '12
Sometimes you just need to step away
"They were shown as everything is shown, for, like the lens of a camera, history is a force that does not discriminate."
JRW <3
Volunteering: IRI - Reset 07/08, Mission Mayhem 07 - Referee
TnT - Referee 07/08, FLL Florida State Tournament - Judge 08/09
Florida Regional 08 - Reset/Repair, Florida Regional 09/10 - Photographer
8 Events - Web Evaluator 08/09/10
Unread 11-02-2006, 08:18
The Arizona Mentor
AKA: Andrew
Ours is held on by duct tape. One side sometimes comes off, but that's because the duct tape on that side isn't long enough.
The fans do help. Ours has been running with no noticable heat problems from simply putting a small muffin fan in the side. (of course we've never let it run more than a half hour continuously).
Unread 11-02-2006, 08:44
Eldarion's Avatar
We built ours exactly according to specifications; out of aluminum with a fan. Those tubes run hot!
-- Thomas Paine
-- Anonymous
Unread 11-02-2006, 09:05
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Cold Cathode tubes really shouldn't get that hot...The one in my computer has been left on for days on end with no issues, but my PC also has much better ventalation compared to a tiny wooden box. I'm thinking more fans to move more air would solve the heat problem.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 11-02-2006, 09:30
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
We built ours (poorly) out of sheet aluminum with the cover held on by 4 zip ties and a small fan for ventilation. I think most of the heat can just bleed through the big holes left by us not bending the metal well, and the small fan can't hurt.
It never really melts.
Unread 11-02-2006, 11:13
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
If the glue melting is causing a problem, I'm sure FIRST will figure out an alternative way to hold the tubes in place. I wouldn't sweat it too much.
Oh, maybe I shouldn't have pushed that...
Unread 11-02-2006, 11:53
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
if you mount it well enough it shouldn't be a problem....when we get tired from working on the robot we just start pelting the green light with balls....
Unread 11-02-2006, 14:15
underwood's Avatar
underwood underwood is offline
lead machinist
AKA: alex
FRC #1072 (Harker Robotics)
underwood is an unknown quantity at this point
we built ours to regulation, with the aluminum box, fan, and velcroed the cathodes to it. it looks great.... looked great. there was no problem with the heat or anything, but a couple of days ago, the programmers had linked it up to an adjustable power supply and someone kicked the aps, sending the voltage from 12 to about 30. X( instant fry-ification. we now have a savaged aluminum box with two store-bought tubes and power converters lying on the base. ugh, at least its still green...
My Famous Last Words Will Be:
"I dunno, press the button and find out."
If life gives you lemons, find someone who's life has given them vodka and have a party.
"Bad artists copy. Great artists steal."
-Pablo Picasso
"Anyone who has never made a mistake has never tried anything new"
-Albert Einstein
MECHANICAL MONKEYS RULE!!!
Vision Target power supply AUWarEagle#1 Electrical 3 18-01-2006 22:17
Does the Vision Target seem rather dim? steven114 Technical Discussion 3 12-01-2006 21:19
vision target Dakota Snow Kit & Additional Hardware 1 08-01-2006 23:00
Vision Target Chassis Mod? AnkurG Kit & Additional Hardware 1 08-01-2006 21:12
