Go to Post "When you lose you don't say anything. When you win you say even less." - Clinton Bolinger [more]
Unread 11-02-2006, 11:36
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
Re: Backwards motor
This is probably a very simple problem. Your motor has probably been wired with reverse polarity: so you can probably just flip the wiring. Put the red wire to were the black one is, and vice versa.
That should help!
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Unread 11-02-2006, 11:54
Bharat Nain's Avatar
Re: Backwards motor
That should help!
on the speed controller that is.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 11-02-2006, 12:02
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Backwards motor
Specifically on the motor output end of the speed controller (labelled M+ and M-). Don't reverse the polarity anywhere else! If you reverse the inputs (V+ and GND) you'll fry the poor controller...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 11-02-2006, 12:21
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: Backwards motor
actually, the wires are right. red-red black-black, and if we change them, someone said we'd fail inspection
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 11-02-2006, 12:35
FIRSTnameisJay FIRSTnameisJay is offline
FIRSTnameisJay is an unknown quantity at this point
Re: Backwards motor
My only concern with simply switching the wires is the actual performance of the motors. I might be wrong on this but those CIM motors travel slower when going backwards than they do when going forwards. Does anyone know if this is correct?
Unread 11-02-2006, 12:48
Re: Backwards motor
A common misconception. The rule for wire colors is
<R81> All wires distributing power with a constant polarity (i.e., except for Relay Module, Speed Controller, or
sensor outputs) must be color-coded as follows:
• Use Red, White, or Brown wire for +12 Vdc and +5 Vdc connections.
• Use Black or Blue wire for Common (-) connections.
Since the wires to motors are not constant polarity, you may reverse these leads to allow the motor to run in the needed direction. You may also make the change in software if you are so inclined. You will not fail inspection for reversing the motor leads at the output side of the controller.
Unread 11-02-2006, 15:21
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: Backwards motor
Remember that the left and right drive train assemblies are mirror images. If you wire them both the same and send the pwm ports the same values say 200, one set of wheels will be going forward and the other set of wheels will be going backwards. Nothing is wrong with the wiring, the software needs to send the opposite values to the left and right sides. If speed is x then 127 - x to one side and 127 + x to the other will have both sets going forward or both going in reverse
Low Cost Planetary Gearbox Source... Joe Johnson Motors 32 14-11-2006 18:02
Inductance of CIMs phrontist Electrical 13 06-01-2006 09:17
Cheap Torque Measurement? ChuckDickerson Motors 15 13-06-2005 13:57
**FIRST EMAIL**/Important Fisher-Price motor and gearbox information sanddrag FIRST E-Mail Blast Archive 1 11-02-2005 18:19
DC motor design project Ian Mackenzie Motors 0 29-01-2005 13:30
