Go to Post Give me more tools; I’ll use the ones that are most useful for the job. - Natchez [more]
Unread 11-02-2006, 09:57
Dan894 Dan894 is offline
FLL #0894
Dan894 is an unknown quantity at this point
Programming Trigonometric Functions
What's the best way to do this. I've heard make a look up table (which I'm not entirely sure how to do anyway, I've never done arrays or array-like things in C), and Taylor polynomials. I've been trying the Taylor approach, but encounter this crude reality that most computers do NOT have infinite memory.
Is defining an integral exponential function like this (recursively) generally a bad idea?
float exp(float base, int exponent) {
if(exponent < 0)
return exp(base, -1*exponent)
else if(exponent == 0)
return 1;
else
return exp(base, exponent-1)
I did a similar thing with factorial...
unsigned long factorial (unsigned character n) {
if(n==0)
return 1;
else
return n*factorial(n-1);
I doubt I'd ever be using that for something bigger than 12! or so.
Of course, since I had some debugging to do, I wound up defining the trig functions using a much more brute force mentality:
float sin(float x) {
return x-(x*x*x)/6+(x*x*x*x*x)/120-(x*x*x*x*x*x*x)/5040+(x*x*x*x*x*x*x*x*x)/362880;
float cos(float x) {
return 1-(x*x)/2+(x*x*x*x)/24-(x*x*x*x*x*x)/720+(x*x*x*x*x*x*x*x)/40320;
Then I defined the other four using ratios... and the arctrig...
float arcsin(float x) {
return x + x*x*x/6 + 3*x*x*x*x*x/8 + 135*x*x*x*x*x*x*x/48 + 1215*x*x*x*x*x*x*x*x*x/384;
float arctan(float x) {
if(-1 < x && x < 1)
return x-x*x*x/3+x*x*x*x*x/5-x*x*x*x*x*x*x/7+x*x*x*x*x*x*x*x*x/9;
else if(x >= 1)
return pi/2-1/x+1/(3*x*x*x)-1/(5*x*x*x*x*x)+1/(7*x*x*x*x*x*x*x)-1/(9*x*x*x*x*x*x*x*x*x);
else
return -pi/2-1/x+1/(3*x*x*x)-1/(5*x*x*x*x*x)+1/(7*x*x*x*x*x*x*x)-1/(9*x*x*x*x*x*x*x*x*x);
And the remaining ones I defined using triangle identities.
Around the term x*x*x*x*x*x*x*x*x/362880, I start getting an error message like
Hence I just give up the accuracy and only get accurate to the 1.6^8/40320 or whichever term I gave up at. And I still don't trust that this code will, you know, actually work. (I also wound up defining
float pi = 3.141592653589793238462548838279; )
Unread 11-02-2006, 11:14
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Re: Programming Trigonometric Functions
What accuracy (how many decimal places) do you really need? For example, take an angles of 1.0, 1.1, 1.01, 1.001, etc and use those to calculate distances in the size of the playing field. What accuracy is good enough?
I forget which college math class it is but they teach how to stop the series based on how many decimal places of accuracy you want. Also consider how many bits is the variable you are using and what accuracy actually fits inside of that. Once these things are considered 20 decimals places for pi does not add to the accuracy.
If you choose to use the math library instead, those almost always have the accuracy and overflow issues sorted out.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 11-02-2006, 11:39
FLL #0894
Am I going to have any problem with slow calculations using the Taylors?
There was an error too... Math section can not fit the section.
And in Calc II they cover Taylor's inequality, which for these trig functions, it gives my accuracy down to (pi/2)^n/n! where n is one bigger than the exponent in the last term.
Unread 11-02-2006, 12:27
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Originally Posted by Dan894
...I've heard make a look up table (which I'm not entirely sure how to do anyway, I've never done arrays or array-like things in C)...
From a couple of days ago: http://www.chiefdelphi.com/forums/sh...78&postcount=4. If you try the search function, you'll find many posts on this topic.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-02-2006, 20:27
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
What's the best way to do this. I've heard make a look up table (which I'm not entirely sure how to do anyway, I've never done arrays or array-like things in C)...
We started with the command line version, and one of students developed a gui frontend, of the program in the following thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=44012
Does the lookup table generation for you.
-Eric
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Functions of '?', ':', and '&' in the C programming language DanDon Programming 8 05-05-2005 09:25
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
