Go to Post The answer the last 3 years would be any regional that 1114 attends. - Cory [more]
Unread 11-02-2006, 12:45
DemonYawgmoth's Avatar
DemonYawgmoth DemonYawgmoth is offline
AKA: Artem Kochnev
FRC #1396 (Pyrobots)
DemonYawgmoth is an unknown quantity at this point
Send a message via AIM to DemonYawgmoth Send a message via MSN to DemonYawgmoth
Using a button on a joystick to track?
We dont want to always have the camera tracking and such, is it possible to start tracking only when a button is pressed, and then stopping when the button is pressed again? What functions would we need to call to use that, and how would we get it to use a different purpose once the button is pressed a second time? I tried doing this before for another purpose but it didnt work, so if someone could help that would be pretty super. Thanks all.
Unread 11-02-2006, 15:58
Jared Russell's Avatar
Taking a year (mostly) off
Re: Using a button on a joystick to track?
try this:
// at beginning of Default_Routine)
static unsigned char p1_sw_trig_old = 0;
// later in your Default_Routine)
if( p1_sw_trig  && !p1_sw_trig_old )
  // Call function(s) to start tracking
else if( !p1_sw_trig && p1_sw_trig_old )
  // Call function(s) to stop tracking
p1_sw_trig_old = p1_sw_trig;
Unread 11-02-2006, 23:26
AKA: Artem Kochnev
ok, but what are the functions that i should be using for getting the camera to start and stop tracking. (thanks for that code, ill try that out on monday)
Unread 12-02-2006, 01:16
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Servo_Track() is the function which performs camera track and search
Unread 12-02-2006, 01:58
AKA: Artem Kochnev
So we would be calling that to start tracking, I'm assuming, from your post? And also, how would we make it stop tracking?
Unread 12-02-2006, 11:17
To have the camera servos track the target, call the Servo_Track() function. To not have the camera servos track the target, don't call the function
Free programming help Cuog Programming 24 24-01-2006 16:43
Change joystick to pwm mapping Joe Lewis Programming 3 30-03-2005 19:27
Joystick Hat button ten3brousone Programming 8 20-02-2005 13:31
Joystick Button programming Bharat Nain Programming 5 18-02-2005 11:48
Joystick Button Deference cibressus53 Electrical 3 01-11-2004 09:38
