Go to Post Slight physical blocks will never stop a good programmer, we can just program around it. - AIBob [more]
Unread 11-02-2006, 12:47
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Using CCP modules
Originally Posted by steven114
I'm trying to count a fast-moving encoder, and instead of having thousands of interrupts firing every second I thought it would be a good idea to use the CCP modules in Capture mode to count the number of ticks. However, ifi_aliases.h says that CCP2-5 all have output buffers on them that prevent them from being used in Capture mode, even if you select USER_CCP in the code. Is it true that there is _no_ way to do this? If not, what happened to CCP1? I couldn't find it mentioned anywhere in the documentations, and cross-referencing from the PIC datasheet to the RC docs didn't turn up anything. Anyone know if CCP1 is available for use?
Thanks,
Steven
Section 17.1.2 of the data sheet might be of interest. This document might also help: http://kevin.org/frc/robot_controller_signal_map.pdf
-Kevin
Kevin Watson
http://kevin.org
Question about kevin's code ImmortalAres Programming 3 23-06-2005 11:13
Vishay IR Reciever modules EIROBOTICS86 Electrical 4 04-02-2004 00:18
Calling all PHP/ASP programmers! blueWarrior FIRST-related Organizations 15 27-01-2004 13:24
The Lowerr LEGO Swerve rlowerr_1 Robot Showcase 4 21-12-2003 23:41
Pre-Season Kit Learning Modules kmcclary Robotics Education and Curriculum 10 21-11-2002 11:37
