Go to Post Build the wrong robot that aims well or build the right robot that can't aim.... decisions, decisions.... - Tom Bottiglieri [more]
Unread 11-02-2006, 13:26
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: White Paper Discuss: .NET (2.0) Composite Dashboard Viewer
Originally Posted by cjelly
Do you think you can release the source for the patch? My team has been working on the dashboard and the new update source code should be helpful.
If you're already working with the source, the only change is to replace line 55 in DataFrameBase.cs in the typelib project with the following:
public int Team_Number { get { return ((data[iCTRL_A] & 0x0F) << 8) | data[iCTRL_B]; }}
I updated the source linked earlier in the thread as well if you want a fresh copy.
I am also recieving "Cross-Thread Operation Not Valid" error messages when I run the main application. Has anyone else experienced this? Do you have a proposed solution?
Sorry, this I have not seen. Have you changed anything?
White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team Jessica Boucher Extra Discussion 1 20-11-2005 20:01
White Paper Discuss: .NET Composite Dashboard Viewer seanwitte Extra Discussion 8 06-04-2005 00:15
White Paper Discuss: 2004 Visual Basic 6 Dashboard Control CD47-Bot Extra Discussion 2 01-02-2005 01:56
White Paper Discuss: 2004 .NET dashboard control dll CD47-Bot Extra Discussion 7 13-01-2005 17:32
White Paper Discuss: Team 810's 2004 Dashboard Backend CD47-Bot Extra Discussion 1 07-03-2004 10:32
