#20
Re: White Paper Discuss: Playstation 2 Controller Adapter
No, you do not have to change any of the sourcecode to use a different programmer.
The comments are unfortunately somewhat misleading, which pins you use for programming are built into the chip itself. The reason for that comment was that we had to move around some of our inputs to make sure the MCLR pin was free to be wired to a custom programmer. This way, we can wire an unused pin on the PS2 plug to MCLR, and when we want to program the chip, we can apply 12volts to that pin and not worry about any of the voltage flowing to the sensitive digipots. |
| White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team | Jessica Boucher | Extra Discussion | 1 | 20-11-2005 20:01 |
| White Paper Discuss: 2005 IRI - Everything You Need to Know (or at least most of it) | Chris Fultz | Off-Season Events | 3 | 17-05-2005 20:14 |
| White Paper Discuss: Joystick Sensitivity Demystified - Version 2 | marccenter | Extra Discussion | 0 | 28-02-2005 16:54 |
| White Paper Discuss: Comparison Paper for Teacher Involvement | CD47-Bot | Extra Discussion | 1 | 13-11-2004 00:09 |
| White Paper Discuss: Controller Circuit- Infrared Emitters | CD47-Bot | Extra Discussion | 1 | 13-02-2004 17:48 |
