Re: Big Cim's vs. Small Cim's
We are using the large CIM for the shooter, works great. What is the diameter of your shooter wheel? Small diameter wheel has lower angular velocity at the rim than a larger diameter wheel. Also, at max rpm a motor has no torque, at 0 rpm a motor delivers max torque. So, big cim has max rpm of 2700, but in the application you will not get this with any load applied. Try some different size shooter wheels at different rpms and you will find your best choice.
| When you go for big balls... | archiver | 2001 | 5 | 24-06-2002 00:54 |
| Size of the field: too big? too small? | archiver | 2000 | 5 | 23-06-2002 22:44 |
| National Venue - 1 big tent! | archiver | 2000 | 0 | 23-06-2002 22:42 |
| Whats the deal w/ big balls? | archiver | 2001 | 6 | 23-06-2002 22:35 |
| 4 big balls on top of the goals | archiver | 2001 | 8 | 23-06-2002 22:27 |
