Go to Post The world isn't changed by people playing it safe. - Andrew Y. [more]
Unread 11-02-2006, 03:19
blue_crew blue_crew is offline
MADTOWN ROBOTICS!!
AKA: Daniel Sheeter
FRC #1323 (Madtown Robotics)
blue_crew is on a distinguished road
Send a message via AIM to blue_crew Send a message via MSN to blue_crew Send a message via Yahoo to blue_crew
Compressor screw attachments?
i was wondering if anyone has a spare little rubber screw that is used to bolt down the compressor or knows where to buy them. thanks.
Unread 11-02-2006, 03:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Compressor screw attachments?
You may be able to get by with a regular screw and a rubber washer between the compressor and mounting surface.
Unread 11-02-2006, 16:46
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
I believe they are 6-32 screws. Check these out McMaster Part# 96905K48. If you have one you might want to measure the major diameter of the screw to make sure its a #6.
Good luck.
Kirk
Excel Attachments? Greg McCoy CD Forum Support 10 20-05-2004 07:35
Dropping attachments? Tom Bottiglieri Rules/Strategy 4 13-01-2004 11:24
does anyone have a source for #25 chain with attachments ajlapp Technical Discussion 5 24-01-2003 17:05
Image Attachments Brandon Martus General Forum 0 19-11-2001 14:50
