Go to Post there should be a continuous cascade of knowledge spilling over to the less experienced team members and and continuous upward flow of members gaining experience. - ebarker [more]
Unread 11-02-2006, 17:44
Ken Loyd Ken Loyd is offline
Who is John Galt?
FRC #0039 (The 39th Aerosquadron)
Ken Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to beholdKen Loyd is a splendid one to behold
ball speed
If you position your robot in the center square at the start of a match and shoot balls through the center goal, have you exceeded the 26 mph speed
limit?
Ken
Ken Loyd
Teacher/Advisor
Team #39
Highland High School
Unread 11-02-2006, 17:46
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Re: ball speed
Just a note it's not 26mph, it's 12 meters/second (36 feet/second).
(Is that actually equal to 26mph? I didn't do the math on it.)
Unread 11-02-2006, 18:02
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: ball speed
It's 26.8 MPH = 39.3 FPS = 12 m/s
The answer to the original question is: Maybe?
A shot from there at max velocity - aimed dead center - should just skim the bottom of the hole. But that dosen't account for drag nor the spin on the ball. If the ball has top spin, then it won't hang as well and would probablly miss low. OTOH, a shot with enough backspin should be able to hit it.
Unread 11-02-2006, 22:40
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: ball speed
limit?
Ken
Which square are we talking about? I've calculated that from the front square it is ~27 feet to the goal, middle is ~30 feet, and back is ~34 feet. With a 45 degree angle shooter firing balls at 12 m/s mounted at about 54 inches high, I believe you could get the balls into the goal from 41 feet ignoring air resistance and spin.
From the first 2 starting positions, I'd say yes, from the back one, maybe...
Unread 14-02-2006, 21:35
Inverted Inverted is offline
AKA: Eric P.
FRC #1228 (Robo Tribe)
Inverted is an unknown quantity at this point
Send a message via AIM to Inverted
Re: ball speed
I calculated the velocity of the ball when fired at full speed (powered directly from the battery) from our device, and it's about 10.5 m/s (25 mph, give or take). As long as you have one wheel shooting, you're legal with any speed. It should shoot from about 25-30 feet.
Unread 14-02-2006, 23:05
The Arizona Mentor
AKA: Andrew
Re: ball speed
If your calculations did not have air resistance, that might not be true, just a warning.
I don't think long range shots will be a problem. 30 feet is do-able, possibly 35...
One wheel shooting will not ensure you're in the legal limits. We shot a ball 47 feet with our one-wheeled shooter, and I know that's not legal.
Unread 14-02-2006, 23:18
DonRotolo's Avatar
Back to humble
FRC #0832
Re: ball speed
I dunno about that, we have a one wheel shooter that was measured at a LOT faster than legal.
Don
Unread 15-02-2006, 09:10
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: ball speed
I think you'll find that ball spin will be the major factor determining whether you make a shot at that distance. If I got my numbers right, a spin of 5 rev/sec would generate lift about equal to the mass of the ball. The vector of the lift is perpendicular to the axis of rotation and the the direction of flight. A back-spin generates positive lift, a front spin negative and side spin causes a curve ball. In any case, we've observed that with back-spin the ball trajectory is more linear than parabolic for 25 ft or so.
NASA has a nice page explaining the effect of lift on a rotating cylinder.
Pete Kieselbach
Unread 15-02-2006, 09:16
Klutch1019 Klutch1019 is offline
None #1019
Klutch1019 is an unknown quantity at this point
Send a message via AIM to Klutch1019
Re: ball speed
For some reason i dont think my team will have a problem with the speed limit or anything on our robot...
Unread 15-02-2006, 09:59
Who is John Galt?
Re: ball speed
Thank you one and all for your responses. I posted the question on FIRST Q & A. The response was that with an angle higher than 30 degrees the shot would be possible and legal. This is good because we are averaging 6 out of 8 in 10 seconds.
Ken
Ken Loyd
Teacher/Advisor
Team #39
ball speed rule? jax1488 Rules/Strategy 6 08-02-2006 14:19
Ball speed trap using 2005 RC eugenebrooks Programming 3 08-02-2006 12:24
Speed Sensor for Ball Shooter Justin Stiltner Electrical 15 28-01-2006 14:40
Speed of the Ball Krazykid Rules/Strategy 1 09-01-2006 13:46
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
