Go to Post Theory (n.) - A mythical place where all robot designs work. - MechEng83 [more]
  #31   Spotlight this post!
Unread 11-02-2006, 17:54
BruceJ BruceJ is offline
BruceJ will become famous soon enough
Re: Video editing help!
Originally Posted by Tom Higgins
I'm confused. First, as I understand, yu want me to export the video track as a .wav file and then later you mention that you need to export the sound track as a .mov file audio only??
Export the Audio track from Premiere. You already have the video sequence you need as I understand it (the image files, targas, etc.)
Export the timeline in Premiere as Audio only to get a .wav file.
This is the audio soundtrack to your entire animation.
To bring it together with your image files to create the Quicktime movie, go to 3ds Max and open the Track View (under graph editors) and select and right-click "sound" to get "properties". Select "choose sound" and your .wav file there.
Now 3ds Max video post will put it together with your images that I assume you have defined in Video post as an image input event.
In video post, create an output image event (if you haven't already) to export the video post to a Quicktime file.
The .wav you created from Premiere and imported using the 3ds Max track view should be the audio that plays when you view the Quicktime movie that you created by running the Video Post in 3ds Max.
  #32   Spotlight this post!
Unread 12-02-2006, 09:59
animatorkid's Avatar
animatorkid animatorkid is offline
ouch
FRC #0079 (Team 79)
Team Role: Animator
animatorkid is an unknown quantity at this point
"There is also a setting, in Quicktime, called 'Enable High Quality Video' which supposedly can make a significant difference in the quality"
DO THIS!!!!!!! It works. If you render in the highest possible quality, and then olay the movie with this setting on, it looks almost uncompressed. And yet, it is compressed, becayse it brought our file size down from 800 megs to 80.
Technically, if you placed a black hole on your robot with enough mass so that your robot is entirely within the event horizon, size constraints will no longer be a problem!
Is that smoke coming from from the victors or servos?!!!
:if only we had an electric beaver!"
you know you play online games too much when your teachers ask why you type "T" before every sentence.
  #33   Spotlight this post!
Unread 12-02-2006, 23:51
tchescow's Avatar
tchescow tchescow is offline
out of control
AKA: Gianfrancesco Venturin
#1156 (Under Control)
tchescow is on a distinguished road
Send a message via ICQ to tchescow Send a message via MSN to tchescow
Team 1156 used ulead video studio 7, ulead video studio 9, pinnacle studio plus 9, pinnacle liquid 6, quicktime and nothing worked! The animation looks like a 320x240 video enlarged to a larger one. We really need help!
C ya! Tchescow!
Under Control - #1156 - Brazil
2005 NJ Engineering Inspiration Award
2004 J&J Mid-Atlantic Judges Award
2003 J&J Mid-Atlantic Rookie All-Star
http://www.undercontrol.com.br
A little inaccuracy sometimes saves tons of explanation.
Saki, "The Square Egg", 1924
  #34   Spotlight this post!
Unread 20-07-2006, 05:28
gopstopper gopstopper is offline
gopstopper is an unknown quantity at this point
premiere.
I often use presentavid 4 such simple edition
Video Editing Software? Kevin Thorp 3D Animation and Competition 16 07-11-2006 13:27
1604 Harmony Hurricanes promo video Barry Bonzack Robot Showcase 11 04-03-2006 18:56
Video: Cyber Blue 234 Late Night Programming Video JAH Robot Showcase 6 13-03-2005 00:34
Video Editing Software? Damelvin 3D Animation and Competition 8 21-02-2005 18:47
Good video footage miketwalker General Forum 0 28-03-2002 17:14
