Go to Post Rules arent built around robots. Robots are built around the rules. - dodar [more]
Unread 11-02-2006, 11:57
CPress CPress is offline
2008 Team Captain
AKA: Matt Peterson
FRC #0754
Team Role: Electrical
CPress has a spectacular aura aboutCPress has a spectacular aura about
Any Way To Edit Manually
Hello,
I am working on programming our robot. Knowing a large amount of C, I type faster than I can drag and drop in the IDE of EasyC. Is there any way to get into a manual mode so I can type all this instead of doing the silly drag and drop? Thanks!!!!
Mathew (CPress) P.
Unread 11-02-2006, 12:00
Re: Any Way To Edit Manually
you can edit name.c files in any editor you want (notepad, wordpad...) as long as you save it as a text file.
Unread 11-02-2006, 12:01
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
You can use the MPLab IDE along with the default code that IFI supplies to do your robot programming in straight C.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 11-02-2006, 12:10
2008 Team Captain
AKA: Matt Peterson
FRC #0754
o i dont need "easyc"?
Unread 11-02-2006, 13:41
Zyik Zyik is offline
Observer
Zyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond repute
Yeah, you can just use MPLab.
This post just to clarify that you don't need easy C.
Team 973 : 06-09
Unread 11-02-2006, 22:04
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
However, if you have other programmers working on the code with you once you start using the MPLAB they may not be able to go back and use easyC. It should be formatting the code in a specific manner.
Sean
Unread 11-02-2006, 22:16
Warning: The IFI default runs on a different library than the code created by EasyC.
I havent used EasyC, but I remember downloading the trial version of FRCoder (the beta of easy c), and being able to type in the bottom right hand corner of the screen. Also, I see no reason why you wouldnt be able to creat your own source files and input them.
How do you edit team informataion Golfer241 General Forum 4 11-02-2006 10:44
default camera code edit Windward Programming 8 25-01-2006 18:33
[wiki]: More restrictive edit policies? Astronouth7303 FIRSTwiki 1 13-12-2005 01:53
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
