Go to Post I’m not decently dressed for this picture.......I have no FIRST shirt, FIRST hat or FIRST pin anywhere on me! - Rich Wong [more]
Unread 11-02-2006, 18:10
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
reverse of motors NOT working please help
Our team is using the standard two motor LARGE cim setup with the kitbot tranny. Our robot drives forward fine, drives backwars fine. When we go to spin around or do a 180 (one motor going forward the other backwards, we have a ton of resistance.) We are using the standard two joystick method for the controls. The drive train doesnt seem tight at all, its only a problem when we are running the motors in opposite directions... Any suggestions??
thanks
STILLIE
Unread 11-02-2006, 18:22
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
Re: reverse of motors NOT working please help
it is quite possible that the load that is being placed on the breakers is higher than 40Amp...I would suggest listening for a popping/clicking noise coming from the breakers if you hear this that may be your problem. If this is your problem you may need to find a way to reduce your friction while turning.
Unread 11-02-2006, 18:26
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Unread 11-02-2006, 18:30
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
thanks
STILLIE
more info as to what type of drive you have. 4 wheel drive, 6 wheel drive 2 wheel drive. we can help better with this info
K.I.S.S
Keeping It Simple Stupid
Unread 11-02-2006, 22:05
Jared Russell's Avatar
Taking a year (mostly) off
(assuming 4WD) You can:
-change treads/tires/wheel design on two or four wheels to reduce traction
-use a castor on a piston to prop up one end of the robot when turning
-reduce the gear ratio to all motors to give more torque
Motors, Motors, and More Motors 1033missions Motors 1 09-02-2006 18:46
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
to all you guys who have played a LOT with these motors.. archiver 2001 1 23-06-2002 23:17
tripping breakers/burning motors Ben Mitchell Motors 16 04-02-2002 13:31
How about new motors? dlavery Motors 31 25-09-2001 19:27
