Go to Post Drive yourself, ride Amtrak or Greyhound bus, or bend space-time to the point of singularity and you'll just poof into existence in Atlanta. - artdutra04 [more]
Unread 11-02-2006, 22:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Starting Box and Field Barrier
Can we be touching the field side barrier before/at the start of the match? Is it included in the starting box? The end goal here is to have a spring loaded part of our robot that pushes on the field side barrier and deploys just by our robot driving away. Is this legal?
Unread 11-02-2006, 22:07
Jared Russell's Avatar
Taking a year (mostly) off
Re: Starting Box and Field Barrier
I don't recall a year when you weren't allowed to start against a wall, as long as you are in the zone...
As for a spring loaded part, I can't remember any official rules, but I don't see why not.
Unread 11-02-2006, 23:51
Touching the wall is legal, and having your robot expand under its own power is also legal (up to 60"). However, there is one minor detail. You have to fit in the sizing box in a self-supporting way. You might consider having a weak, springy latch on the part that springs out when you start driving, just to be on the safe side. Here is the rule on that:
<R06>
The starting configuration of a robot immediately prior to being enabled by the Arena Controller at the beginning of a match is the basis upon which a robot will be inspected for compliance with the maximum allowed size. This configuration of the robot must fit within a FIRST Sizing Device that has the following inside surface dimensions: a flat, level rectangular base 28 inches x 38 inches, and a height of 60 inches. Other than resting on the floor of the Sizing Device, no part of the robot may break the plane of the sides or top of the Sizing Device during size inspection. The robot must be self-supporting while in the Sizing Device.
Oh, and you must keep any springs on the robot for the entire match (<R08>).
Unread 12-02-2006, 00:12
Thanks Eric. It looks like the "self supporting" phrase will rule out what I had in mind. We'll find another way.
Unread 12-02-2006, 00:17
Sanddrag, here's a suggestion. A loose latch, one that will jam the part in but remove itself or release the part at a slight impact/movement of the robot will work. Example: 330's 2004 bot had a thin piece of aluminum to hold an arm piece in the box. If we moved slightly, the arm piece flopped free.
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
Multiple tetras in field of view Mr. Lim Programming 0 14-02-2005 14:52
pic: 2005 Field 3D Model Available For Download Alexander McGee Extra Discussion 11 16-01-2005 13:49
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Human Player and Box Placement Gamer930 Rules/Strategy 2 05-01-2003 00:03
