Go to Post The code won't compile if you violate the rules of the programming language...but English is more robust, it seems to work pretty well no matter how we engineering nerds mangle it! - MrForbes [more]
Unread 12-02-2006, 00:24
Craig Roys's Avatar
Craig Roys Craig Roys is offline
Coach - Team 1718
FRC #1718 (The Fighting Pi)
Craig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond repute
pic: Team 1718 Treads
2016 Waterford District - Semifinalists and Entrepreneurship Award Winner!
2016 Troy District - District Winner and Chairman's Award Winner!
2016 MI State Championship - State Champs with 27, 67, and 6086 and Entrepreneurship Award Winner!
2016 FIRST Championship - Carson Field Quarterfinalists
Unread 12-02-2006, 00:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Team 1718 Treads
Very nice. Where did those treads/belts come from and what part number are they?
Unread 12-02-2006, 10:14
Craig Roys's Avatar
Coach - Team 1718
The belts are custom made by one of our sponsors - Industrial Extrusion Belting in Cassopolis, MI.
Unread 12-02-2006, 11:19
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Is there only one tread assembly on each side of the robot? If so, I think you may have some stability issues if you decide to persue the ramp (unless your really short, which you can't really tell from the picture).
Sweet looking treads though.
Unread 12-02-2006, 19:26
matt101 matt101 is offline
matt101 is an unknown quantity at this point
What is the tread made of? From the picture it looks like its some type of rubber or something.
Unread 12-02-2006, 19:44
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
It doesn't look like you get much traction on those; rather smooth, but it really depends on the total weight of the bot, I guess.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 13-02-2006, 05:44
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
80/20?!?!?!?!?!?! I LOVE 80/20!!!!!!!! So strong and yet so light, the t-brackets, where they can slide ina dnout, no rivting, ahhhhh, the bliss of this stuff. lol, sorry, I just love the stuff so much.
FLL Team - Hackberry Hill Elementary - Arvada, CO ('08 - '10 Coach)
FRC Team 1636 - Reds Robotics - Arvada High School - Arvada, CO ('05 - '07 Alumni)
FRC Team 1583 - Rambotics - Ridgeview Academy - Watkins, CO (Volunteer/Supporter)
FRC Team 2859 - Blasterbots - CSM Robotics Outreach - Golden, CO ('09 - '10 Coach)
FRC Team 3320 - Miracles & Machines - Eastside Memorial High School - Austin, TX ('10 - '12 Mentor)
Unread 13-02-2006, 09:36
Craig Roys's Avatar
Coach - Team 1718
Yes, just one tread assembly per side. The treads are just under 24" end to end and we are 38" wide. We have no problems climbing the ramp head on. If we turn sideways, we can bottom out, but we've yet to find a position we can't get out of - at least one of the treads always has contact with the ground. We also have at least 80% of our total weight low on the robot to help with stability on the ramp.
Unread 13-02-2006, 09:40
Craig Roys's Avatar
Coach - Team 1718
That's what I thought when I first saw them, but I was proven way wrong. The rubber on the outside, although smooth, is very soft so it grips well. It pushed a 180 lb person sitting on their butt across the carpet with the robot weight only around 50 lbs. And because of our short and wide config, we are still able to turn easily enough.
Unread 13-02-2006, 10:20
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Just to remind you that although the part was made by your sponsor and it might have been donated, you still have to have it in the B.O.M. and the materials that went into making the product acounted for in the overall cost of the robot. Although it was free, there was still some expence in making it and that has to be accounted for.
But those treads are quite nice, the smooth surface might not get as much traction as a ruffed up one though, in my opinion I would lightly take a file to it (a rough one) to give them a little more grip. I also love the use of 80-20, that stuff is soo awsome!
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 13-02-2006, 11:03
bbehnke bbehnke is offline
The Behnkenator
AKA: Bria
FRC #1676 (Pioneeres)
bbehnke will become famous soon enoughbbehnke will become famous soon enough
Send a message via AIM to bbehnke
very nice, those wheels look like they weigh 20lbs. each
Unread 13-02-2006, 12:40
Craig Roys's Avatar
Coach - Team 1718
Each wheel is just under 3.5 lbs. Each tread assembly is about 12 lbs. The chassis in that picture weighs just under 50 lbs.
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Need Help and Suggestions - Creating a TEAM Freddy Schurr Team Organization 7 30-03-2005 22:00
What's the best organizational structure for photos? maikull Chit-Chat 2 17-03-2005 17:47
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
