Go to Post Adversity should be seen as a challenge and not as an obstacle. :D - waialua359 [more]
Go Back   Chief Delphi > Other > Car Nack's Corner
Unread 10-02-2006, 15:41
Car Nack Car Nack is offline
Car Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond repute
Car Nack Predicts 3/06
FIRST will have problems handling the numerous claims that robots are exceeding the ball shooter intial velocity of 12meters per second.
Car Nack has spoken.
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: Car Nack Predicts 3/06
Agreed.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 10-02-2006, 15:47
I certainly hope Car Nack is wrong, but I'm pretty sure he's right. We shall see.
Unread 10-02-2006, 20:58
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
I am 99% sure that he is right!
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 10-02-2006, 21:06
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
ida_noeman is on a distinguished road
It's going to be pretty difficult to judge how fast the balls are coming out.
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
Unread 11-02-2006, 01:12
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I think that Car Nack will be wrong on this one _IF_ FIRST adopts one simple policy. In NASCAR, if Team A believes Team B has put a car with prohibited modifications on the track, they can request a tear down inspection by the authorities. If they are right and Team B has an illegal car, then Team B is penalized appropriately (up to and including having a "win" rescinded). However, if Team A is wrong and the challenged car is perfectly legal, then Team A has to pay for the tear down and rebuild. This is their penalty for filing a false charge. A similar policy could be instituted at the competitions if excessive spurious "they are shooting too fast!" charges become a problem.
-dave
Unread 11-02-2006, 10:02
yee haw!
-dave
But what does team A pay? Krispy Kremes?
Ricky Quinones
Unread 11-02-2006, 10:57
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
I definitely agree with Car Nack, and completely disagree with Dave. (Sorry, Dave )
Although it is a fantastic solution, I feel that the desire for low match turnaround time at a FIRST event will overpower any "checks" such as Dave proposed, or any other additional "check" than the inspection at the beginning. I can imagine that after the first time a team overturns a decision based on ball speed, teams will be more attune to the problem and thus request a check more often than if the issue was nipped in the bud even before the event begins.
Teams need to trust that every team is keeping within the rules set out by FIRST. I know they don't all the time, but I think the only way to stick to the idea of "referees calls are final" is by not allowing an overturn. Poor match calls can make-or-break the team perspective of an event, and thus referees should be chosen for their experience, so that if a situation arises it can be handled quickly and correctly. Selecting experienced referees also cuts down on the amount of issues missed, and decreases the amount of overturns.
Bottom Line? Which would you rather have, more matches while trusting your opponents are keeping within the same rules that you stuck to, or less matches and distrust of every team out there? I think we've come too far as the FIRST Community to regress to the latter decision.
Side note: If it is not addressed in the season, I think FIRST will be overwhelmed in the team forums about this particular point. And, it's not like that hasn't happened before!
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
Unread 11-02-2006, 11:20
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
Since FIRST is incorporating an UL person to help with Safety Inspection, they should incorporate a State Trooper with a speed gun to check the exit velocity of the Poofballs.
The team is issue a speeding ticket and require to appear in front of the Robot Inspector again- 3 times and you're DQ.
Seriously, maybe a speed gun can be used to check the speed of the balls?
Has anyone try it?
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 11-02-2006, 11:54
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I apologize for not following every Q&A thread, but didn't FIRST say that the ball exit velocity was going to be judged based on going X distance when fired at Y angle?
It seems to me that this should be the test.
A team is supposed design robots that meet this test.
There are 100's of ways to cheat, but we don't plan on teams cheating.
Teams could sneak in extra fix it window hours or fudge accounting or or or.
I think that most teams will try to follow this rule if they are given a way to know if they are in violation.
A simple rule that is easy to verify seems to me to be the best friend of folks who want to see teams play by the rules.
Joe J.
Team #88, TJ2
Unread 12-02-2006, 00:29
Negative. That was given in the rules as a guide, however someone asked Q&A(I think a search through the Rules/Strategy forum should turn up a few threads on this) and recieved an answer to the effect of, "we're still trying to decide which one or combination of the following (list of methods)". Using this method as a test is also risky because you need to account for shooter height when you do it, otherwise tall shooters will complain that short shooters can shoot faster.
Unread 12-02-2006, 00:53
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
I think i like Dave's Idea, play it like Football you ask for a play to be reviewed and you are wrong you pay the consequences, If redabot says that blueabot's balls were being shot too fast and redabot was wrong, then Redabot should either get a 10 point penalty or possibly even a DQ for the soul reason of causing a hold up
and it shouldnt be just one team, if there are 3 teams in an alliance then the 3 teams should agree upon the review of the robot if they dont then no go,
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 12-02-2006, 04:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Has anyone try it?
We've used a radar gun to measure ball speed. It can be very inaccurate if the ball is not traveling in/close to the same plane in which the gun is pointing.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-02-2006, 08:25
Billfred's Avatar
Billfred Billfred is offline
Perhaps the simpler solution is to use a nice and natural part of the planet to our advantage: gravity.
If you can tilt a robot so that it shoots vertically and measure the height from floor to shooter in centimeters, you can have it fire a ball and time how long it's airborne. Throw in some simple math, and bada-bing, you can tell in about ten seconds whether it's legal on the velocity side.
In fact, I'm sure Kevin Watson has been hiding in his workshop doing some black magic with an old RC, some limit switches, and a piece of string cheese to accomplish just that.
Unread 12-02-2006, 09:10
REVving up for a new season
FRC #2848 (All-sparks)
you can't be sure that 100% of the teams are going to be able to fire straight up, there are alot of teams with gravity feeds.
I am personally a fan of the radar gun. We had an officer come in and test ours yesterday and it seemed fairly accurate based on our calculations. The main thing is FIRST just needs to make it a standard for each comp. If a radar gun is used the same person set up in the same way for every team, so even if the gun is off everyone will be on the same playing field.
I was also thinking maybe we could make a custom poof ball with a build in accelerometer and a tiny micro processor. Then the teams would have to shoot that ball and whatever it says goes. just like these for baseballs. http://www.lillianvernon.com/catalog....jsp?pdId=2877
Now that i think about it i might go buy one of those baseballs and transplant it into a poof ball to see how it works.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Car Nack Predicts #4 Car Nack Car Nack's Corner 1 14-04-2005 10:57
Car Nack Predicts #4 Car Nack Car Nack's Corner 0 29-03-2004 11:18
Car Nack predicts #3 Car Nack Car Nack's Corner 2 03-03-2004 09:24
Car Nack Predicts #2 Car Nack Car Nack's Corner 1 06-02-2004 12:48
Car Nack Predicts Bill Beatty Off-Season Events 4 11-11-2001 12:12
