Go to Post Just to be clear, NOTHING anyone says here is a confirmation. The ONLY source for official answers to questions like this is the FIRST Q&A system. - dlavery [more]
Unread 11-02-2006, 21:37
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: How to use a "Timer"
The new PIC is 8722 not 8720 and the processor runs at 40 MHz but the prescaler examples are assuming the procesor is running at 10 MHz.
This is the actual Pic18F8722 data sheet:http://www.kevin.org/frc/PIC18F8722_ds.pdf
Check out the OpenTimer#() functions in this PDF:
http://www.kevin.org/frc/C18_libraries.pdf
It's very useful.
That is just he C18 complier library to help with timers and stuff but not the actual Pic data sheet.
Unread 12-02-2006, 01:25
CronosPrime1 CronosPrime1 is offline
FRC #0321
CronosPrime1 is an unknown quantity at this point
How do I use another timer? The way I'm having things work right now, I'm already using Timer 1 to do something. Now I want another timer to do something else? How can I do that? And if there are two timers firing interrupts at the same time, is that going to mess things up? I heard that the five timers in the FRC are all different, so how do I use another timer?
Unread 12-02-2006, 01:27
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
It wasn't meant to be a link to the datasheet, and yes it is in fact a 10MHz clock. I'm using those to generate a 4ms overflow timer, and I've verified its speed by having a printf every 250 overflows (one second) and timing it with my watch, as well as a few other people who concur, its definitely 10MHz.
void Initialize_Clock(void)
/* Use Timer3 (16-bits) to control our clock */
/* timer set to 4 ms */
  OpenTimer3(TIMER_INT_ON &
             T3_16BIT_RW &
             T3_SOURCE_INT &
             T3_PS_1_8
  // Maximum for 16-bit 65535 - 5000 (4ms) = 60535
  WriteTimer3(CLOCKOFFSET);  /* Preload timer to overflow after 4ms */
Make sure to include timers.h
Matt Krass
Unread 12-02-2006, 14:18
6600gt's Avatar
AKA: Lohit
Sorry I ment the clock speed is 40 MHz but the timer incriments one every 4 of them. Same with the processor instructions cycle. It is 1/4 the speed of the clock.
The example has a 10MHz clock but but the acutal ticks on the timer are only 2.5 MHz so per second(assuming 1 to 1 prescale). So on the robot controller you have to multiply that number by 4 to get the real number of ticks per second( If you are going by the example in Kevin Watson's interrupt code or the data sheets).
Unread 12-02-2006, 16:44
Matt Krass's Avatar
AKA: Dark Ages
Huh?
I've never heard of it running a 40MHz clock and none the tests I've run support that, they do however support a 10MHz clock.
For example, the code example I posted previously is a 4ms clock.
I preloaded the timer with 60535 so it would overflow 5000 ticks later (65535).
4ms / 5000 = 800 ns per tick
1 second / 800 ns = 1,250,000 ticks = 1.25 MHz
1.25MHz * 8 (1 to 8 prescale) = 10MHz
If I missed something, can you point out where I can find it? I'm genuinely confused and I don't understand where you got your numbers from.
Hopefully helping,
Matt
Matt Krass
Unread 12-02-2006, 18:08
6600gt's Avatar
AKA: Lohit
I am now confused too. This is what I know:
The PIC's have an internal hardware PLL(Phase Loop Lock hardware multiplier). I can't find the setup of this of RC but if you connect a 10MHz crystal to a pic and turn on hardware PLL, its like running 40 MHz crystal.(Don't ask me how it does it, I have no clue, try the data sheet) But they might have just hooked it up directly to a 40MHz clock, I guess you can do it.
I see this everywhere Foso/4, I am guessing but I think it means frequency of the oscillator(clock). I might be screwing up the technical terms.
In the Data Sheet I found this "One instruction cycle consists of four oscillator periods...".
So 10 MIPS * 4 = 40MHz
oscillator is just a crystal or resonator that oscillates or resonates at a particular frequency.
Don't worry about it. All you need to know is that the processor executes at 10 MIPS
Unread 12-02-2006, 18:28
Matt Krass's Avatar
AKA: Dark Ages
Ahhhh. Thanks for clarifying that, I wonder what the deal is with that....
However you're right, basing the timers and ticks on 10 million a second works. Perhaps after ship you and I should take up a research project to demystify this?
Matt Krass
Unread 12-02-2006, 19:09
6600gt's Avatar
AKA: Lohit
Perhaps, I have already started working with an individual PIC form Microchip.
I ordered a sample pack for free. I am currently working on 18F458.
10MIPS
32k code spack
1.5k RAM
256bytes EEPROM
A free chip with similar processing power as the RC!! Though I took a little while to get it to work. I can run a servo directly off a pin on the chip!!!
Where do you want to start?
Unread 12-02-2006, 21:27
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
10MIPS
32k code spack
1.5k RAM
256bytes EEPROM
Are you using a breadboard? A programmer? Would you mind detailing your setup? I'm interested in playing with something like this outside of FIRST.
Thanks,
Unread 12-02-2006, 21:56
6600gt's Avatar
AKA: Lohit
I am using a breadboard and a very cheap programmer(took me 20 hours of websurfing to find one that I could buy all the parts at radioshack).
http://www.picbasic.co.uk/forum/arch...php/t-703.html
You will need a data sheet for your particular pic.
PGD = data
PGC = clock
Vss = ground
Vpp/Vdd = power
All you need is a serial plug and some wire and registers.
Software is http://www.ic-prog.com/
I prefer the 18F series chips because the C18 compiler is readily available. Unless you want to program in assembly, then you can get any pic.
Just order a sample pack(up to 15 chips) umm....chips
To date I have only ordered one sample pack with 12 16f series chip and 3 18f series. A good free compiler for the 16f series has been hard to find.
Another big plus for 18F series is that you can easily use the code written by Kevin Watson, with a few modifications.
In fact, I looked through the IFI default code to understand the structure and impliment it into my pic.
Unread 14-02-2006, 17:06
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
It sounds like you're still a little unclear on how this stuff works.
The PIC18F8720 (and presumably others) has a PLL as an option. This allows you to multiply the frequency of the oscillator that is used as the clock source. Whether IFI impliments this or not, I don't know (their website only quotes 10MIPS). So, if we have a 10MHz crystal and take advantage of the PLL, the PIC sees a 40MHz crystal. The datasheet mentions that this would be good to do of you are worried about having external high frequency signals.
The Foso/4 you see refers to what the PIC does with the clock. Each instruction cycle is 4 clock cycles. If you connect a 40MHz crystal, instructions are 10MHz. The details should be in the datasheet, but in essence, it takes the processor 4 clock cycles to process an instruction.
What you need to take away from this: The PIC in the RC is 10MIPS.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
