Go to Post ...I pretty much got the impression that the balls are actually very small, cuddly landmines. - Gui Cavalcanti [more]
Go Back   Chief Delphi > Other > FIRST Lego League
Unread 11-02-2006, 23:35
Iseekknowledge's Avatar
Iseekknowledge Iseekknowledge is offline
Iseekknowledge is an unknown quantity at this point
BrickOS problems
Hey, i don't know if this is the right spot for this so if it is feel free to move it. but heres my delima. i'm operating off of a linux system (Ubuntu 5.04 Hoary Hedgehog) and i downloaded BrickOS-0.9.0 and all of the stuff it needs (gcc-h8300-hms-2.95.2.2.1) and i was able to download the firmware using
$ firmdl3 /usr/local/lib/brickos/brickOS.srec
but then i try to use dll and it doesn't work, so heres everything that i typed and the result from dll in verbose mode
$ cd /programs/BrickOS/brickos-0.9.0/demo
$ make
$ dll -v helloworld.lx
C.P. Chan & Tyler Akins - USB IR Tower Mode for Linux.
opening tty...
LNP Initialized...
loader hostaddr=0x00 hostmask=0xf0 portmask=0x00
delete
#time 2939359759 00 try 0: ack:0
try 1: ack:0
try 2: ack:0
try 3: ack:0
try 4: ack:0
error deleting program
when i do this the light turns on on the IR tower but i don't see anything happening on the RCX. and i was able to download the firmware so i know that it isn't a hardware problem
i've looked all over the forums and haven't found my answer, so i decided to post one. i would greatly appriciate your input.
"True knowledge is to know the extent of ones ignorance." Confucious
"The more we learn, the more we realize how little we actually know." Unknown
"Ignorance is the only enemy in this war, the war of cyberspace" Iseekknowledge
"Those who are willing to work hard often lap those who don't" Iseekknowledge
"Knowledge; without it this wouldn't exist" Iseekknowldege
Unread 12-02-2006, 01:43
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
Re: BrickOS problems
It has been a year since I have worked with BrickOS so I don't know the exact details. You may want to check the flags you can set on the dll program there may be some options there which can help. I noticed you already use the -v flag which is helpful. Another flag I remember helping us was the speed or rate of transer. Sometimes the baud rate you are running at could cause a problem if you are running too fast for your tower.
Another issue I barely remember has something to do with BrickOS and when you install it if the options are slightly wrong you won't be able to communicate with it through the tower. I hope this information helps.
-Nick
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
Unread 12-02-2006, 21:59
ok thanks for the input, i also followed the instructions in the readme.usb file and entered in
$ sudo mknod /dev/usb/legotower0 c 180 160
$ sudo chmod 666 /dev/usb/legotower0
and it made it so that the time was there (#time 2939359759 00 try 0: ack:0) before i used those commands all i got was #deletetry 0: ack:0 but the system recognized the tower it said that it was /dev/usb/legousbtower0 where as after i typed in $ sudo mknod /dev/usb.... then i had two legotower0 and legousbtower0
so i'll play around with it a little more and will look into changing the baud rate.
Unread 02-03-2006, 23:41
PIRATECAPTIN's Avatar
PIRATECAPTIN PIRATECAPTIN is offline
Logo desigenr
AKA: Jim aka Paul Bunyan
FRC #1732 (Hilltopper Robotics)
Team Role: Marketing
PIRATECAPTIN is on a distinguished road
Man I wish you could help you out here. But my knowledge is center more on the design of a lego bot. Have you tried Robo lab by any chance? I may not be a programer but I have heard many recomendations on Robolab.
Yo ho! Yo ho! A Pirate's Life for me!
-Pirates of the Carribean
Unread 03-03-2006, 00:08
ya i looked into that, but my problem is that i need an OS that can support decimals, and i'm pretty sure that robolab doesn't. BrickOS was the only one i could find taht supported decimals. you see, i need decimals because i'm trying to make the robot ballance an inverted pendulum, and to do this you need to find velocitys, which most of the time are decimals. and i just can't multiply the velocity by 100 because once it devides D/T it already rounds it. so thats why i need to go with BrickOS.
Unread 12-11-2006, 15:20
Brickos works great for me. Attached is the makefile that I use to compile and download. To download the code, I type:
make load
To download and run the code, I type:
make run
Anyone Else Having Problems with Q&A on FIRST? Windwarrior General Forum 6 25-01-2006 10:54
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Vanilla ice cream == car problems?? Ken Leung General Forum 16 22-11-2005 11:07
Joystick problems archiver 2001 3 24-06-2002 02:40
