Go to Post So I usually end up looking pensive or confused. :) - Karthik [more]
  #136   Spotlight this post!
Unread 11-02-2006, 20:21
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: 3D Animation Q/A
Originally Posted by Damelvin
Just clearifying on rendering, if I have teh camera just moving and nothing else important or text I dont have to set up teh safe mode or is that just a guideline? I am going to render these into tga format and use premier to put together. And then from tehre do I compress it and format it to quicktime and dv-ntsc?
Dont use permier it will turn out crappy. Download and use Avid free dv
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
  #137   Spotlight this post!
Unread 12-02-2006, 02:08
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
Quick question had problem with this last year, how would I have a tire spin if its part of the robot and the whole robot is already rotated? I mean taht makes the wheel spin really weird. Any way to constarin it or make it spin in place?
Hear about the cannibal that passed his brother in the forest.
  #138   Spotlight this post!
Unread 12-02-2006, 10:07
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
ok, animate the wheel on it's own, before the robot is animated. then, link it to the robot, and then animate the robot.
if the robot is already animated, use the curve editor to adjust the rotation of the wheel. curve editor is accessed by a button at the top that looks like a graph with lines on it. you only want the wheel to have movement in one direction, so that means set all the graphs to 0, except for one.
  #139   Spotlight this post!
Unread 12-02-2006, 10:57
abroerman's Avatar
abroerman abroerman is offline
AKA: Alex Broerman
FRC #0868 (Techhounds)
Team Role: Animator
abroerman is on a distinguished road
I've got a quick question...
In the rules, it goes about describing the 5 second slate that is to appear at the beginning of the animation. The bullet just after that states, "Credits may follow that still frame..."
I interpreted this as saying that the credits should go after the slate (not after the animation itself), but every other team I've seen has put the credits at the end. Can someone clear this up (and if I was wrong, what possible effect may this have on the judging process)?
Thanks and good luck teams,
-alex
  #140   Spotlight this post!
Unread 12-02-2006, 11:37
Animator
Team Role: Animator
i have never seen the credits go between the splash and the animation. the credits get cut out of ther animation at the competition, so i think they want it at the end. It's easier to cut the end off an animation than the middle.
  #141   Spotlight this post!
Unread 12-02-2006, 12:35
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
-alex
Unless they messed up in the wording- (i didn't double check) The still frame they are refering to for the credits to folow- is the Black still- Remember- they want slate- black-anim-black-credits.
  #142   Spotlight this post!
Unread 12-02-2006, 19:18
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Just wondering if someone can get me a video of scrolling numbers like in the matrix?
  #143   Spotlight this post!
Unread 12-02-2006, 20:58
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
I guess no one could find one o well I just finsihing up everything. Mad though taht is looks really nice adn then since I was rushed teh end doesnt look good oh well 1 guy animating I think I did better than last year so whatever I probably post it later tonight.
  #144   Spotlight this post!
Unread 12-02-2006, 21:11
animator1's Avatar
animator1 animator1 is offline
Animator
FRC #1312 (Syntax Error)
Team Role: Animator
animator1 is an unknown quantity at this point
um, i don't have a video of it, but you can use this .gif i found on the matrix website of it, and in turn make it into a video. or even this screensaver (i'm sure you would know how to do that)
  #145   Spotlight this post!
Unread 12-02-2006, 21:24
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
THats katakana and kanji. Thanks for help Ill look for a gif.
  #146   Spotlight this post!
Unread 12-02-2006, 21:32
animator1's Avatar
Animator
Team Role: Animator
i've also found this, http://www.tutorialized.com/tutorial...e-vision/10234 and this http://www.tutorialized.com/tutorial...e-vision/10234 not sure how much this will help, but can't wait to see your animation.
  #147   Spotlight this post!
Unread 12-02-2006, 22:00
Tyr's Avatar
Tyr Tyr is offline
AKA: Colin Windmuller
FRC #1086 (Pirates of the Black Pearl)
Team Role: Animator
Tyr is an unknown quantity at this point
Can you have still images in your 5-second slate?
Just because I can't spell it
doesn't mean it didn't happen.
  #148   Spotlight this post!
Unread 12-02-2006, 22:02
animator1's Avatar
Animator
Team Role: Animator
whoa, double post. oh well, i will say it again too i guess lol. yes, i know i do, and i have seen many teams have it. especially in past years too.
  #149   Spotlight this post!
Unread 13-02-2006, 11:50
darkstar's Avatar
darkstar darkstar is offline
Animator
FRC #0585 (Warrior Robotics)
darkstar is an unknown quantity at this point
Send a message via Yahoo to darkstar
Holy freaking A! My team has the only rookie animation entry for my regional!
  #150   Spotlight this post!
Unread 09-02-2007, 19:43
greenstriker greenstriker is offline
Junior Member
None #9999
greenstriker is an unknown quantity at this point
Yeah, I have a question.
Are there any initiation files, or files we must fill out specifically for the animation that our team must submit for the competition?
Sorry, I was browsing all of the sites, and I couldn't find anything.
Animation Question Velaes 3D Animation and Competition 15 02-02-2005 00:11
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
