#17
Re: Has anyone else had trouble staying within the 10 second limit in autonomous?
Has anyone actually tried tracking while disabled?
Kevin's code uses the PWM outputs which output neutral while disabled. Can Kevin's code command servo values through the camera? That is, can you plug the servos into the camera itself, and still control where they point? |
| Autonomous Code trouble | The yellowdart | Programming | 16 | 21-01-2006 10:36 |
| A Warning to Human Players During Autonomous | The Lucas | General Forum | 21 | 07-04-2005 02:29 |
| Setting Autonomous Settings from OI | Tom Saxton | Programming | 15 | 27-03-2005 11:45 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
