Go to Post So.... football pizza water game with minibots and megabots? - euhlmann [more]
Go Back   Chief Delphi > Other > Car Nack's Corner
Unread 12-02-2006, 09:30
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Re: Car Nack Predicts 3/06
Car Nack is wise and I agree.
Certainly there will be many complaints about teams that exceed the 12 m/s rule.
Resolving the complaints will be interesting to watch and I am not even sure how or why they would consider doing it.
You know that resolving the complaint WILL NOT slow the throughput by testing the accused on the field of play.
Post inspection of the accused is possible if a method and location is readily available to resolve the accusation - but I can't believe that 10 -20 minutes after a match AND the accusation is resolved - the scores would be revised.
The NASCAR example is fine except it takes them TIME to resolve the complaint and they do it back in the garage - AFTER the race.
This is an issue that needed a clear methodology defined and included in the inspection process. It would be nice to be informed what that method will be in advance so we can validate using the same methodology before hand.
We used the guideline that was included at kickoff to validate, as we don't have access to a radar gun or other sophisticated equipment. We compensated the distance to include for being a certain distance from the horizontal (the ground).
Our design drives the motors through a speed controller so if we do exceed the velocity rule we will dial down until we meet it - but that does kill all our pre-work establishing the correct autonomous settings for the controls.
What does 12 m/s look like anyways?
Unread 12-02-2006, 10:08
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
well, just drive a car at about 43 km/h (roughly 27mph) and you'll find out
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Unread 12-02-2006, 11:43
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by EricH
Negative. That was given in the rules as a guide, however someone asked Q&A(I think a search through the Rules/Strategy forum should turn up a few threads on this) and recieved an answer to the effect of, "we're still trying to decide which one or combination of the following (list of methods)". Using this method as a test is also risky because you need to account for shooter height when you do it, otherwise tall shooters will complain that short shooters can shoot faster.
This seems to me to be unfortunate. It does two bad things.
#1 It continues the uncertainty. What FIRST teams need more than anything is a quick ruling that they know they can trust to not change. Uncertainty causes delay or forces teams to go with a safer but less optimal solution. In both cases teams are justified in being upset with FIRST.
#2 It takes away an easily repeated test method from team. 30 Degrees is easily measured. The height of the shooter from the ground is easily measured. The distance a ball flies is easily measured. Seems as good of a method as anyone could have hoped for.
Does anyone have any insight into why there has not been a clear ruling on this? The only thing I can think if is that the folks in CO may have less air resistance than they have at Altanta, but I think teams can deal with that.
I don't think that the robots will be significantly more dangerous if balls exit the robot at 12+delta m/s in Altanta and 12-delta m/s in Denver especially if they fly the same distance.
As for me, I hope FIRST rules in favor of the Angle, Height, Distance method.
Joe J.
Team #88, TJ2
Unread 12-02-2006, 12:13
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
From what I have been told wouldn't spin on the ball effect the distance the ball where to travel?
We used a photogate like sensor system to measure our shooter velocity on our prototype and got different measurements then when we used a radar gun.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 12-02-2006, 12:41
volunteer helper
FRC #6099 (Knights)
I think you missed my point, but thanks for converting it to mph for me.
I wanted to get a feel for what it looks like as an observer - if I drove, the perspective would be different than if I were stationary, watching something fly out at 12 m/s. I think that an object moving at a constant velocity may not "look the same" as an object moving at an instantaneous velocity.
If accusations are based on what something "looks" like - we could be surprised to find out that we were wrong.
Unread 12-02-2006, 13:04
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Jon got it right. The problem with the simple "height, angle, distance" method is that it is a very basic analysis of the actual flight dynamics of the ball that does not account for several (legal) variables that can significantly affect the distance traveled. For example, the distance guideline given in the manual is based on the initital constraint of no spin on the ball when it exits the robot. During some experimentation, we found that putting a serious backspin on the ball - while keeping all other performance parameters the same, including the 12m/s exit speed - could increase the distance traveled by up to 30%. If FIRST were to rely on just the "height, angle, distance" analysis, they would incorrectly classify a shooter that put a lot of backspin on a ball, and thereby got increased range, as an illegal solution.
-dave
Unread 12-02-2006, 13:22
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
has anyone here played paintball? If you have then there is your answer. Paintballs are only allowed to travel about 300-350 ft per second. Before you enter the feild you have to get your gun clabrated and you shoot your paintball gun though a small barrle that tells you how fast you are shooting. I will see if i can find a pic.
shaun
Unread 12-02-2006, 13:25
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
but I believe that the paintball chronographs only work with faster velocity's (300 mph! *edit 200 mph*). I am pretty sure that 12 m/s would not measure on a paintball chronograph.
http://www.wcsrobotics.com
team 663
team 1493
Unread 12-02-2006, 13:27
nuggetsyl's Avatar
FRC #0025
nope its 300 feet a sec
http://www.ehow.com/how_8414_calibra...tball-gun.html
shaun
Unread 12-02-2006, 15:00
FRC #1493 (Falcons)
yeah, i know its 300 ft/sec. I accidentally typed a 3 instead of a 2
300 ft/ 1 sec * 3600 sec/1hr * 1mi/5280 = 204.5 mi/hr
I play tournament paintball, and usually shoot around 280 fps, but mph is so much easer to understand to the average person
whoops , but its still far faster than the 12 fps of a poof ball
team 663
team 1493
Unread 12-02-2006, 15:03
nuggetsyl's Avatar
FRC #0025
its 12 meters per sec
that about 38.4 fps
or 27 mph
shaun
Unread 12-02-2006, 15:05
FRC #1493 (Falcons)
whoops! wow, i am just full of mistakes today, sorry
team 663
team 1493
Unread 12-02-2006, 16:15
AKA: Dr. Joe
FRC #0088 (TJ2)
-dave
I agree that there are going to be difference due to spin. And I appreciate that FIRST is trying to do the right thing.
My thoughts are basically this. Safety is the main concern. There are 2 aspects to safety: If the balls are exiting too fast, someone could get hurt from a short range direct hit. If the balls go too far, unsuspecting folks will take a hit.
If we classify the exit speed by range, we only take care of the second but not the first.
Or have we?
I don't think there is anything magical about getting hit with a 12m/s Poof ball vs a 15m/s Poof ball (which is 25% higher than the "true" limit). I realize that it would have 56% more energy, but I don't think there is a bright line between what will hurt a human and what won't. Robots are dangerous things as are the machines we use to make them. I don't think even a 15m/s Poof ball is among the more significant risks associated with building and competing FIRST robots.
There is also something to be said for a limit that all teams can easily test for themselves.
I would urge FIRST to go with the angle, height, distance method, knowing that it is going to be wrong in some cases but that an obviously flawed standard that is easily implemented & understood is better than an improved standard that is less easy to implement & yet to be defined in Week 6 of the design/build cycle.
Joe J.
Team #88, TJ2
Unread 12-02-2006, 16:29
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
I point to the answer given on the Q & A when the official answer asked the team if they would provide a complete cover for the entire field ( wording was like that).
How about if all teams brought a piece of Poly carb and we covered the entire field after attaching them all together?
I make light (humor) because the real issue is not being addressed even as we approach the end of build.
What is the EXACT way the rule will be applied - MEASURED -TESTED or whatever. The Game committee better have an answer or there will be many unhappy teams.
Mike Martus
Unread 12-02-2006, 16:30
Billfred's Avatar
Billfred Billfred is offline
I wasn't particularly worried about hanging in 2004 (1293 had bigger concerns, like moving...), but how were the hangers with their 10-feet-per-second limit enforced? I don't have a 2004 manual in front of me, but I seem to recall the basic requirement being that teams had to prove through math or testing or black magic voodoo that their hanger was within the requirements.
If I'm right, what's stopping us from implementing a similar thing this year?
Car Nack Predicts #4 Car Nack Car Nack's Corner 1 14-04-2005 10:57
Car Nack Predicts #4 Car Nack Car Nack's Corner 0 29-03-2004 11:18
Car Nack predicts #3 Car Nack Car Nack's Corner 2 03-03-2004 09:24
Car Nack Predicts #2 Car Nack Car Nack's Corner 1 06-02-2004 12:48
Car Nack Predicts Bill Beatty Off-Season Events 4 11-11-2001 12:12
