Go to Post You know you are a true tech geek when you end up on top of the Sears tower, and the only pictures you post are the ones of the radio antennae. ;) - Tom Line [more]
Unread 12-02-2006, 14:02
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Error Linking for '05 RC
Trying to utilize last year's RC, we have tried to follow Kevin's instructions. However we have gotten the following error on linking:
Error - section '.code_serial_ports.o' can not fit the section. Section '.code_serial_ports.o' length=0x000002d4
Any suggestions on what this means and what we can do to correct the problem?
Jon Mittelman
Team236
Unread 12-02-2006, 14:16
Re: Error Linking for '05 RC
Jon Mittelman
Team236
Sounds too big to me.
Check to see the amount of space your code takes up on the 2006 RC before you ported it.
MPLAB -> View -> Memory Usage Gauge (but multiple the program space usage by 2 to get # bytes)
or
look at the .map file that can be created in your project directory.
Realistically you have around 29K bytes available on the older RCs.
Unread 12-02-2006, 14:30
Jon236's Avatar
AKA: Jon Mittelman
or
Thanks....I came up with 36.6 k for our 2006 code....will try to trim it!
Jon
