Go to Post Build the wrong robot that aims well or build the right robot that can't aim.... decisions, decisions.... - Tom Bottiglieri [more]
Unread 12-02-2006, 16:17
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Has anyone else had trouble staying within the 10 second limit in autonomous?
To help with the whole searching problem, we're going to try to initialize the camera so it will automatically turn to face about where the target is, then search from there. That saves a second or two of sweeping around looking for the light.
The ability to start facing any direction is what really helps this year. Since we shoot out of the side of our robot, we are going to start with our side facing the front of the field, and simply drive backwards (which will be left because of the robot orientation) a bit while everything locks onto target and the wheel gets up to speed, then fire as fast as possible.
We'll see how well auto firing works. I'd be worried about defensive bots purposely ramming you, except that you must specify which zone to start in BEFORE the match, which means they can't move their robot to try to hit yours. They can use a switch to pick a different mode and turn to come after you though.
And a last note, why do you need to move to shoot? The center of the three starting positions are 27, 30, and 34 feet from the goal.
Unread 12-02-2006, 16:27
Umm Errr...
Originally Posted by lkdjm
Does anyone actually plan to shoot in autonomous?
plan yes, but we will see how that works out
1139 Alumni
Unread 12-02-2006, 17:53
lkdjm's Avatar
lkdjm lkdjm is offline
AKA: David Mazza
FRC #0564 (Digital Impact)
lkdjm will become famous soon enough
Send a message via AIM to lkdjm Send a message via Yahoo to lkdjm
I feel that that is too far away. It is possible that we will shoot from the starting position, but we haven't tested our new robot yet (I am working and testing on last year's robot, which has the same chassis design) so I am not sure how good our cannon will be. It's a good idea, but I think a: it may be too far; and b: the robot next to you might get in the way. I will definitely consider that plan.
-Thank you all for the suggestions! Keep them coming.
-David Mazza
-Longwood Team 564 programmer
- 564.first@gmail.com
- http://www.longwoodrobotics.org
- http://longwoodrobotic.6.forumer.com/
Longwood's Digital Impact
Unread 12-02-2006, 18:10
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
I would be interested to see teams that have had a chance to test this, but it seems to me that it would be really difficult to make it from anything but the front starting position at 27 feet from the goal. If you go with the 12m/s in FIRST's rule, and their discussion on being able to shoot 32 feet at the fastest speed, you really shouldnt be able to hit the goal at 30 feet away. But again, we keep getting conflicting answers with our testing and physics, so I would reserve judgement until I see a test that verifies a ball shooting at 12m/s makes it a certain distance.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Autonomous Code trouble The yellowdart Programming 16 21-01-2006 10:36
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
